A restart doesn't always work with Firmware updates !
Try a power Cycle.
A safe shutdown is preferred.
sudo /etc/init.d/z-way-server stop
Sudo shutdown
Wait till the leds go off.
Turn off the power for 10 seconds.
Where to get the firmware
Re: Where to get the firmware
Thanks @micky1500
I proceeded as you suggested, unfortunately to no change in the firmware and SDK. Still shows 7.26 SDK 7.17.00.
I hope someone from support can come to my rescue.
Best wishes.
Best wishes.
Cesar
My Razberry 7 Pro is also stuck on 7.26 SDK 7.17.00.
It seems there is no upgrade path after going to 7.26, if I am reading this graph correctly.
https://service.z-wave.me/expertui/uzb- ... ith_hidden
Hi @ScottR,
Thanks for chiming in!
Indeed, the graph you linked seem to indicate that, after 7.21. it's either 7.26 (which my Razberry 7 Pro is currently running) OR 7.28, meaning I could have gone from 7.21 straight into 7.28...
I thought I had to go from 7.21 into 7.26 and from there to 7.28... the graph seem to indicate otherwise.
I appreciate you posting this information as it gives me some peace of mind as I thought I had somehow borked my brand new Razberry 7 Pro!
I hope you are right and that someone from z-wave.me eventually catches this thread and clarifies.
Have a nice weekend!
Cesar
You are right, there is no path from 7.26 to 7.28, but you can download the 7.28 firmware manually and use it to upgrade from 7.26. It is not always good to do such jumps between firmwares if we don't have a corresponding path, but for this particular 7.26->7.28 it is okay. You can do it
On the graph click on 7.21 and you will get the file name to go to 7.28. For your case it is: https://service.z-wave.me/expertui/uzb/ ... .02.01.gbl
this morning I tried update from 7.26 to 7.28 - this failed through the bootloader uplaod.
Now I can't access to the Razberry 7 ...
With tool - also no success
./ZMESerialUpdater serialapi_uzbupdate -f Razberry07.17.02.01.gbl -d /dev/ttyAMA0
What can I do?
What can I do?
Please be more specific. You did Bootloader update instead of Firmware update with the gbl file downloaded from our site? It should not kill the board, but we can try it.
Hi Polto,
yes, I did Bootloader update instead of Firmware update with the gbl file downloaded from your site .... at the ui of z-way ... this crash the Razberry
root@raspberrypi:/home/pi# ./ZMESerialUpdater serialapi_uzbupdate -b Razberry07.17.01.02.glb -d /dev/ttyAMA0
Z-WAVE Serial API Tool
Version:LWE0.9
by Z-WAVE>ME
Device ready in:3.05902791023 seconds
BOOTLODER
Openning port .............................. OK
Error 0 Hex file contains invalid record at line 1 while loading the bootloader
file:Razberry07.17.01.02.glb
Waiting for Boot reflashing .............................. OK
Device ready in:3.03512787819 seconds
FULL INFO
SERIAL INFO
VERSION: 07 1C VENDOR: 01 47
ZME_CAPABILITIES
UID: 11 FF DB FC 90 92 10 13 80 81 6F 3A 78 35 F3 F1
VENDOR: 5B 3D NODES: 71
FLAGS:
04 05 90 73 6A DB CF FC F0 DC 13 57 1E E6 54 1E 2F 09 0C DB 59 C3 F4 55 8C 27 C1 CC 2B 61 FC 73
84 F0 C9 5D 41 6C 1D 86 C5 B7 27 62
FIRMWARE CRC
BOOT: FF FF FW: FF FF
MISC
FREQ: EU
NVR Content
Prog/erase lock : FF FF FF FF FF FF FF FF, Read back lock: FF
Rev FF, Cal FF, TXCal FF FF, SAW FF FF FF FF, Pin FF, CRC FF FF
NMV: CS FF, TYPE FF, SIZE FF FF, PSIZE FF FF (EEPROM Unknown)
USB: VID FF FF, PID FF FF, UUID FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FACTORY ID: WEEK 255, YEAR 255, CHIP FF FF, SER FF FF, WS 255, HWREV: FF FF, CRC8 FF
elapsed 13.9839439392 seconds
root@raspberrypi:/home/pi# ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0 | grep -E "(FREQ|VERSION)"
FREQ: EU
