Problem with Fibaro Motion Sensor
pofs
Re: Problem with Fibaro Motion Sensor
Post by pofs »
edafonseca wrote:I'm not reveiving any report from fibaro Motion sensor.
Check that RaZberry is included in Association Group 3 of Motion Sensor.
Also play with config parameters 40, 42, 60, 62, 64.
By default reports are not sent regularly, only when value changes more than threshold. Default threshold is 1 degree Celsius for temperature, and 200 Lux for illumination.
edafonseca
Post by edafonseca »
Thanks for your reply, I think you find the problem.
In Device configuration, Association, there is no values set (neither for group 1, 2 or 3). But I have no selector to set any device in group 3, do you know how can I associate Razberry to this group ?
fredaim
Post by fredaim »
@pofs
effectively when I said not to see illumination it was in Domoticz.
In fact z-wave-server, according to the tests I've done, works better than OpenZWave. But it is better implemented in Domoticz. And I use Domoticz...
I expect future versions of HA UI ...
@edafonseca
You can set the group assignment in expert mode in the last tab of the Blue UI.
edafonseca
Thank you ! It's working great now :)
fredaim
Post by fredaim »
edafonseca wrote:Thank you ! It's working great now :)
good fun ;)
pofs
Post by pofs »
fredaim wrote:@pofs
Domoticz has the same flawed implementation as previous versions of Blue UI:
if ((_device.instanceID==0)&&(haveMultipleInstance))
    continue;
I even think they've copied it from ours JS :)
As I think Motion Sensor has multiple instances, the sensor on default instance might be not present. And sensors on non-default instances probably have only one scale.
    continue;
This was removed few weeks ago (mostly due to Fibaro). So, update to the latest RC code to get it.
blackkane
Post by blackkane »
if you have some problems with the sensor settings you can use the "curl" command (I suggest you to read the manual to have more informations about the parameters). For example:
set 42 param
curl "http://127.0.0.1:8083/ZWaveAPI/Run/devices\[21\]instances\[0\].commandClasses\[112\].Set(42,180,2)"
set 80 param (light on/off)
curl http://127.0.0.1:8083/ZWaveAPI/Run/devices\[21\].instances\[0\].commandClasses\[112\].Set(80,0,1)
Best regards, b.
Confuzer
Post by Confuzer »
When I am in the blue expert UI I am unable to set parameter 40, as the UI sets the scroller and input field as "min 32769 max 32769". Same goes for all other interval settings.
So now I almost never get updates, only if motion is detected.
Can I set it another way? Thanks!
In expert tab
