I solved the riddle.
Checking back in the app it shows me just the name field. This seems not to be intended, because the apps module.json looks like it should show a lot more options. This is what I get:
https://goo.gl/photos/MWqpb4ZHegBrgghr5
So I kicked out the CloudBackup app and today in the morning everything was just fine.
For the record: the most easy way checking what apps are using cron, seems to check out the instances API call:
<IP>:<PORT>/ZAutomation/api/v1/instances
