Where to get the firmware
herbert-f
Re: Where to get the firmware
Post by herbert-f »
This is okay ...??
root@raspberrypi:/home/pi# root@raspberrypi:/home/pi# ./ZMESerialUpdater serialapi_uzbupdate -d /dev/ttyAMA0
                                        Z-WAVE Serial API Tool
                                             Version:LWE0.9
                                             by Z-WAVE>ME
Device ready in:1.08714699745 seconds
          FULL INFO
Openning port                            ..............................                            OK
          SERIAL INFO
                 VERSION:  07 1C  VENDOR:  01 47
          ZME_CAPABILITIES
                     UID:  82 CE 2D 6D 56 4C F7 65 8C 07 B2 61 13 A0 D6 00
                  VENDOR:  1D DD   NODES: 83
                   FLAGS:
 B6 0E 07 6B 54 17 E5 F1 43 88 4C 1E 7E 6F 44 1C 0E 07 D8 90 FB 1C EB 79 3A 03 73 F2 CF 6B FE 19
 75 7C 4B B2 11 26 7E 3C CE C4 49 5C
          FIRMWARE CRC
                    BOOT:  FF FF      FW:  FF FF
          MISC
                    FREQ:  EU
                                         NVR Content
          Prog/erase lock :  FF FF FF FF FF FF FF FF, Read back lock: FF
          Rev FF, Cal FF, TXCal  FF FF, SAW  FF FF FF FF, Pin FF, CRC  FF FF
          NMV: CS FF, TYPE FF, SIZE  FF FF, PSIZE  FF FF (EEPROM Unknown)
          USB: VID  FF FF, PID  FF FF, UUID  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          FACTORY ID: WEEK 255, YEAR 255, CHIP  FF FF, SER  FF FF, WS 255, HWREV: FF FF, CRC8 FF
          elapsed 1.40290999413 seconds
But no UserInterface to flash firmware:
Controller Info
 The inspect queue will open a second window to allow monitoring the commands sent out by this controller.
Role in Network
Node Id:
Home Id:
Primary Role:	No
Primary Capability:	No
SUC/SIS in network:
Hardware
Vendor:
Vendors Product ID:	/
Z-Wave Chip:
Firmware
Library Type:
SDK Version:
Serial API Version:
Capabillities:
UUID:
Subvendor:
Nodes limit:
Controller Static API
Allow max RF power
Backup/Restore
Battery save on sleeping
Advanced network diagnostics
Z-Wave Long Range
Fast communications
Change vendor ID
Promiscuous mode (Zniffer)
Full Zniffer
RF jamming detection
Capabillities:
Software Information
Version number:
Compile-ID:
Compile-Date:
UI
UI version	v1.5.9
Built date	02-04-2022 00:10:16
Functions:
I also get an email:
SmartHome UI - Notification
The following notification appeared in Your Z-Way System:
Cannot start Z-Wave binding: Error: Bad data - communication failed
Best Regards
Z-Wave.Me
Looks like some internal fields got mangled... Please show me your Z-Way start log. Your board is definitelly fixable remotelly.
herbert-f
Post by herbert-f »
Do you mean the
z-way-server.log
at /var/log/ ???
I can't find "attachements" at the PM formular???!!!
z-way-server.log. Please send to support@z-wave.me and a notice to send to Pavel and PS
