Problem with Fibaro Motion Sensor
Re: Problem with Fibaro Motion Sensor
It is a known v2.2.3 bug https://github.com/Z-Wave-Me/ExpertUI/issues/197. It is also mentioned in the release notes of version 2.2.3 in the announcements section of this forum
Hi all,
I have a Fibaro Motion Sensor 3.2 version (I have other 2.7 version and work fine), the interview is 100% complete, but Motion sensor event not sent or captured for controller. The device only send Luminiscence.
Attach log when motion event is sent to controller:
In device type show unknown device type: 7
https://postimg.org/image/3ocnbkvdj/
Regards.
[2016-07-04 13:42:00.035] [D] [zway] RECEIVED: ( 01 08 00 04 00 0B 02 98 40 22 )
[2016-07-04 13:42:00.036] [D] [zway] SENT ACK
[2016-07-04 13:42:00.036] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-07-04 13:42:00.036] [I] [zway] Node 11:0 CC Security: sending Nonce Report
[2016-07-04 13:42:00.037] [I] [zway] Adding job: Nonce Report
[2016-07-04 13:42:00.037] [D] [zway] SENDING (cb 0xf7): ( 01 11 00 13 0B 0A 98 80 BE C7 5F F5 CB A6 48 5A 05 F7 BA )
[2016-07-04 13:42:00.045] [D] [zway] RECEIVED ACK
[2016-07-04 13:42:00.046] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-07-04 13:42:00.046] [D] [zway] SENT ACK
[2016-07-04 13:42:00.046] [D] [zway] Delivered to Z-Wave stack
[2016-07-04 13:42:00.080] [D] [zway] RECEIVED: ( 01 07 00 13 F7 00 00 04 18 )
[2016-07-04 13:42:00.080] [D] [zway] SENT ACK
[2016-07-04 13:42:00.080] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-07-04 13:42:00.080] [D] [zway] SETDATA devices.11.data.lastPacketInfo.delivered = True
[2016-07-04 13:42:00.081] [D] [zway] SETDATA devices.11.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-07-04 13:42:00.081] [D] [zway] SETDATA devices.11.data.lastPacketInfo.deliveryTime = 34 (0x00000022)
[2016-07-04 13:42:00.081] [D] [zway] SETDATA devices.11.data.lastPacketInfo = **********
[2016-07-04 13:42:00.081] [D] [zway] SendData Response with callback 0xf7 received: received by recipient
[2016-07-04 13:42:00.081] [D] [zway] SETDATA devices.11.data.lastSend = 31569238 (0x01e1b556)
[2016-07-04 13:42:00.081] [D] [zway] Job 0x13 (Nonce Report): success
[2016-07-04 13:42:00.081] [I] [zway] Removing job: Nonce Report
[2016-07-04 13:42:00.097] [D] [zway] RECEIVED: ( 01 23 00 04 00 0B 1D 98 81 13 07 BE 76 35 59 79 F0 C0 AB 5B 6F E0 69 F7 C3 58 CF BE B1 40 30 FC 8A F4 A0 69 AF )
[2016-07-04 13:42:00.097] [D] [zway] SENT ACK
[2016-07-04 13:42:00.097] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-07-04 13:42:00.097] [I] [zway] Node 11:0 CC Security: Received a secure message
[2016-07-04 13:42:00.097] [D] [zway] SETDATA devices.11.instances.0.commandClasses.152.data.firstPart = **********
[2016-07-04 13:42:00.098] [I] [zway] Node 11:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 08 00 ]
[2016-07-04 13:42:00.098] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2016-07-04 13:42:00.098] [D] [zway] ( zero-length buffer )
[2016-07-04 13:42:00.098] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.event = 8 (0x00000008)
[2016-07-04 13:42:00.099] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.eventString = "Motion detected, location unknown"
[2016-07-04 13:42:00.100] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2016-07-04 13:42:00.100] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7 = Empty
[2016-07-04 13:42:13.376] [D] [zway] Job 0x13: deleted from queue
[2016-07-04 13:42:20.575] [D] [zway] Job 0x13: deleted from queue
[2016-07-04 13:42:30.717] [D] [zway] RECEIVED: ( 01 08 00 04 00 0B 02 98 40 22 )
[2016-07-04 13:42:30.717] [D] [zway] SENT ACK
[2016-07-04 13:42:30.717] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-07-04 13:42:30.718] [I] [zway] Node 11:0 CC Security: sending Nonce Report
[2016-07-04 13:42:30.718] [I] [zway] Adding job: Nonce Report
[2016-07-04 13:42:30.718] [D] [zway] SENDING (cb 0xf8): ( 01 11 00 13 0B 0A 98 80 E8 E9 AA CC CC D1 AD 93 05 F8 5D )
[2016-07-04 13:42:30.727] [D] [zway] RECEIVED ACK
[2016-07-04 13:42:30.728] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2016-07-04 13:42:30.728] [D] [zway] SENT ACK
[2016-07-04 13:42:30.728] [D] [zway] Delivered to Z-Wave stack
[2016-07-04 13:42:30.883] [D] [zway] RECEIVED: ( 01 07 00 13 F8 00 00 0F 1C )
[2016-07-04 13:42:30.883] [D] [zway] SENT ACK
[2016-07-04 13:42:30.883] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2016-07-04 13:42:30.884] [D] [zway] SETDATA devices.11.data.lastPacketInfo.delivered = True
[2016-07-04 13:42:30.884] [D] [zway] SETDATA devices.11.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2016-07-04 13:42:30.884] [D] [zway] SETDATA devices.11.data.lastPacketInfo.deliveryTime = 155 (0x0000009b)
[2016-07-04 13:42:30.884] [D] [zway] SETDATA devices.11.data.lastPacketInfo = **********
[2016-07-04 13:42:30.884] [D] [zway] SendData Response with callback 0xf8 received: received by recipient
[2016-07-04 13:42:30.884] [D] [zway] SETDATA devices.11.data.lastSend = 31572184 (0x01e1c0d8)
[2016-07-04 13:42:30.884] [D] [zway] Job 0x13 (Nonce Report): success
[2016-07-04 13:42:30.884] [I] [zway] Removing job: Nonce Report
[2016-07-04 13:42:30.903] [D] [zway] RECEIVED: ( 01 24 00 04 00 0B 1E 98 81 31 4A C1 EB 3B D3 B8 A8 62 2F 30 FD 21 A9 D2 3F B9 B4 D2 E8 E4 C3 8C 84 35 FC 93 BA 67 )
[2016-07-04 13:42:30.903] [D] [zway] SENT ACK
[2016-07-04 13:42:30.903] [D] [zway] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
[2016-07-04 13:42:30.903] [I] [zway] Node 11:0 CC Security: Received a secure message
[2016-07-04 13:42:30.904] [D] [zway] SETDATA devices.11.instances.0.commandClasses.152.data.firstPart = **********
[2016-07-04 13:42:30.904] [I] [zway] Node 11:0 CC Security: passing decrypted packet to application level: [ 71 05 00 00 00 ff 07 00 01 08 ]
[2016-07-04 13:42:30.904] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.eventParameters = byte[1]
[2016-07-04 13:42:30.904] [D] [zway] ( 08 )
[2016-07-04 13:42:30.904] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.event = 0 (0x00000000)
[2016-07-04 13:42:30.905] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.eventString = ""
[2016-07-04 13:42:30.906] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2016-07-04 13:42:30.906] [D] [zway] SETDATA devices.11.instances.0.commandClasses.113.data.7 = Emptyhttps://postimg.org/image/3ocnbkvdj/
Regards.
Set device description via expert Ui. You get a big list with all device settings load this settings in your fibaro Ms.
Greatings from the noob
Hi Wikibear,Wikibear wrote:Set device description via expert Ui. You get a big list with all device settings load this settings in your fibaro Ms.
The device description included it when adding the device to the network, it is not a problem.
subir fotos gratisOn the other hand, indicates that the device always awake.
Interesting automatic detection doesn't work with my sensor.
At this position where you are now make a network test. Hold B button 2-4 sec when purple comes up push again. If you wait to long and you push at yellow you will reset your device to default factory settings.
If you device glow green all is fine. If you device blink green then yellow and after this red, then you have network trouble.
Check your log files for transmission of data.
The device is in the same room as the controller to 4 meters distances. The test is OK, the device glow green all.Wikibear wrote:Interesting automatic detection doesn't work with my sensor.
Your device version is 3.2 also?
No 2.7 after 3m get Network error. That's why I ask you to put this device direct in range to controller for testing.
Did you get any log entry's? Did you send all settings to device?
Wikibear wrote:No 2.7 after 3m get Network error. That's why I ask you to put this device direct in range to controller for testing.
The problem is with 3.2 version (Node 15), I have other device 2.7 (Node 2) version and work fine.
imagRe: Problem with Fibaro Motion Sensor
Can you show Screenshot of configuration page via expert Ui?
