lanbrown
Post by lanbrown »
otverber wrote:
20 Jun 2023 10:56
tried it, but
this command through putty:
wget -qO - https://storage.z-wave.me/z-way-server/ ... _armhf.deb | sudo bash
returns theese errors
bash: line 1: syntax error at "newline", which is an unexpected symbol
bash: line 1: `!<arch>'
have tried typing the command letter by letter, but the samme error is returned
what's wrong?
Then try this:
wget - https://storage.z-wave.me/z-way-server/ ... _armhf.deb
sudo dpkg -i z-way-4.0.3_armhf.deb
otverber
Post by otverber »
PoltoS wrote:
26 Jun 2023 18:02
@otverber Your queue looks ok - 22 sent packets - nothing wrong here. But If you still think there is an issue, please send us the log on support -mail (with a link to this thread).
The problem others are experiencing is a different one. Could someone with this issue help us by providing remote access to chase the issue? We are still unable to reproduce it ;(
hello
where do I find the support-mail adress?
The Z-way log file is very large, the job queue list isn't that large will try to capture both lists for you. I suspect a flood at midnight..
support@z-wave.me ;)
Please purge the log before starting and do
sudo killall z-way-server -HUP
to let it rotate the log
Hello @hubert, @otverber, @AlesKO, @JohannesF, @J.nissen
Since we can't catch it for a few weeks, we made a new build where we enabled additional queue inspection on the http://localhost:8083/expert/#/network/queue page. Please install the new v4.1.0-22-g964ba9d9 (https://storage.z-wave.me/z-way-server/ ... _armhf.deb) and once the issue happens again (jobs are stuck in the queue and nothing is sent out), please provide the log file and the queue inspector (better as a page save to .html [Ctrl + S] rather than a screenshot). Hope it will allow us to track it down.
Thank you in advance for your help in improving Z-Way!
hubert
Post by hubert »
Thanks @PoltoS, I have installed the new build and will send info next time it happens
On the most recent hang that happened, according to /expert/#/device/status a Fibaro Dimmer 2 device was the last to be updated before the queue hung
otverber
Post by otverber »
PoltoS wrote:
27 Jun 2023 03:58
hello
please indicate how to install the new update;
which commands trough ssh should i use?
RandomTask
Post by RandomTask »
Use this command to install this version of the z-way package. You can replace the contents of PKG= with another version
PKG=z-way-4.1.0-22-g964ba9d9-lws16_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKG
otverber
Post by otverber »
PoltoS wrote:
27 Jun 2023 03:58
RandomTask wrote:
27 Jun 2023 16:50
thanks a lot, it worked! :D
otverber
Post by otverber »
hubert wrote:
27 Jun 2023 09:55
I just reincluded a Fibaro dimmer 2(#75>#202), and the Z-Wave version vent from 4.24 to 6.51 in (zz):8083/expert/#/device/type
I have a FIBARO Single Switch 2 (#82) that are still on 4.24; will try exclude and include tomorrow.
hubert
Post by hubert »
otverber wrote:
27 Jun 2023 23:44
hubert wrote:
27 Jun 2023 09:55
Z-Wave Version is showing 6.51.06 for me on my Fibaro Dimmer 2, not sure if this has changed recently
Device firmware version 3.04, as far as I know it's not possible to update this through Razberry/Z-Way.
All of my devices (Fibaro, Aeotec, Goap) are on Z-Wave version 6.51.06 except 1 Remotec thermostat which is on 4.54.01
