New release candidate of available now!
SolarFlor
Re: New release candidate of available now!
Post by SolarFlor »
I add a number of advises when I update HA
14/06/14 - 8:27Can not instanciate module SwitchControlConstructor: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 8:27Can not instanciate module Demo1: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 17:4Can not instanciate module Demo1: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:10Can not instanciate module SwitchControlConstructor: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:10Can not instanciate module Demo1: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:17Can not instanciate module SwitchControlConstructor: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:17Can not instanciate module Demo1: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:50Can not instanciate module SwitchControlConstructor: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:50Can not instanciate module SceneConstructor: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 18:50Can not instanciate module Demo1: TypeError: Cannot read property 'meta' of undefinedhide14/06/14 - 19:5Can not instanciate module Demo1: TypeError: Cannot read property 'meta' of undefinedhide
Demo1 was certainly removed?
If you had your modules, copy them manually to modules folder.
SolarFlor
Post by SolarFlor »
PoltoS wrote:Demo1 was certainly removed?
what do you mean?
should I cancel manualy some folders before to update HA?
Remove it from the UI. If it will not work (might not), remove from storage/config_xxxxx_json.
Excuse, it was a demo/developers module we removed at some point.
SolarFlor
Post by SolarFlor »
Many Thanks. I will try soon
To all whom it may concern:
viewtopic.php?f=3422&t=20451
SolarFlor
Post by SolarFlor »
pofs wrote: Try to replace existing XML with this one, and see if resolves your issues (not sure if it addresses all the errors, but most of them).
Is this still needed? I have included the device but all values are not upadating
alboon
Post by alboon »
PoltoS wrote:@alboon: check out latest from git. It should work now
I'm just install 1.7.0-rc2 and I'm still in error mode !! :
28/06/14 - 7:37Can not instanciate module 3: TypeError: Cannot read property 'meta' of undefined
How I can fix it ?
I would suggest to first update to the latest official 1.7.1 release.
alboon
Post by alboon »
thx, after update to 1.7.1 add message : module not found in the list of all modules.
EDIT : I've got message but it work ! thx a lot
