Is there any sample software for door lock given with the razberry ?
I have door lock sample application included in the z-wave SDK (bought from Zensys).. Is that sufficient to control door locks ?
About door locks
It is sufficient, but it
It is sufficient, but it would be hard to use with RaZberry, since the s/w is for Windows, while the RaZberry is for Raspberry Pi box. Unless you find a Windows for Raspberry Pi
We will release RaZberry s/w that will work with Door Locks soon. Please stay tuned.
I see , another question
I see.. I have other questions !
What should i modify in the given source codes for door lock (given with razberry) ? How can i implement that ?
Could the current openzwave source files (lock,security) enable door lock control ? if so , how is that (implementation) ?
Thank you
Thank you
The next version of RaZberry
The next version of RaZberry s/w will include DoorLock suppoort. It is comming!
We can not reply you about Open Z-Wave. You are better to look on their code and read wiki/forums.
