New version of RaZberry is released
LOCOSP
@Holland Hi, after changes go
Post by LOCOSP »
@Holland Hi, after changes go to MAP TAB and the save button will be active ;)
Holland
Ahh, thanks. That's indeed
Post by Holland »
Ahh, thanks. That's indeed the solution. Thanks for your help
Zetat
Fibaro RGBW?
Post by Zetat »
Has the new update support for Fibaro RGBW?
For version 1.4 one of the
For version 1.4 one of the API changes is:
Command Class SensorBinary data tree has changed. Now it contains sensor types like SensorMultilevel.
I do not understand what this means. If I read the documentation about Command Sensor binary in section 13.8 page 60, I do not see references to sensor types SensorMultilevel
I have the Fibaro Universal Sensor which contains two binary (open/close), and four multilevel (temperature) sensors. The temperature sensors (which if left alone are automatically updated) are not updated any more if I poll the binary sensor with:
zway.devices[N].instances.SensorBinary.Get()
The binary sensor does not automatically update.
Please try out v1.4.1-rc1.
Please try out v1.4.1-rc1. There are not much changs in it, but this particular problem is fixed.
The Sensor Binary no indeed
The Sensor Binary no indeed contains types like Sensor Multilevel. This is because Sensor Binary CC V2 allows this. Your Universal Sensor supports only V1 and it is saved as [1]. The manual will be updated accordingly. The .Get() should update all supported sensors. You just might need to force interview if you have switched from v1.3.1
Thanks for the clarification.
Thanks for the clarification. I'll look into this again. As a matter of fact I did start working with Universal sensor recently after I had upgraded to 1.4, and also did a couple of "force interview"
Bjorn
v1.4.1-rc1
Post by Bjorn »
How to get hold of that version?
/ Björn
Use the same commad as to
Use the same commad as to install Z-Way, but specify the version you need:
wget -q -O - razberry.z-wave.me/install/v1.4.1-rc1 | sudo bash
Holland
@PoltoS
Post by Holland »
@PoltoS
I tried installing 1.4.1 rc1 with wget -q -O - http://razberry.z-wave.me/install | sudo bash
but that reverted me back from a 1.4+ build to 1.4 (24-09-2013)
