Reading Sensor Value of Aeon Labs HEM - getting NULL
danilo
Post by danilo »
Hi there,
I am trying to read the sensor values (Watt) of the Aeon Labs HEM.
In the RaZberry UI I can see the wattage per Clamp. (But the Update function more often then not does not update the values).
Then I issue the following JSON calls:
http://IP_RAZBERRY:8083/ZWaveAPI/Run/devices[2].instances[0].commandClasses[0x31].Get()
followed by:
http://IP_RAZBERRY:8083/ZWaveAPI/Run/devices[2].instances[0].commandClasses[0x31].data.val.value
All I get as an answer is NULL. But that is the way I am supposed to get a Multisensor-Report, isn't it?
How can I get the Wattage per clamp with JSON? (3 clamps).
Somehow it would be useful to see the data model of the connected devices on RaZberry, so that I know which JSON call will get me the meter data. (or any other data I need to read).
Does anybody know how I can get the Wattage values from the Aeon Labs HEM?
Regards,
danilo
EDIT:
After much trial and and error I seem to get the clamp Wattage out with the following commands:
http://IP_RAZBERRY/ZWaveAPI/Run/devices[2].instances[2].commandClasses[0x31].data.val.valueOf(0)
Whereas the number in instances is the clamp number, i.e. instances[2] = clamp 2
However there is still a problem. Get() does not update the data . The value of val only changes after a manual update through the Demo UI.
Any ideas how i can get the data updated before reading it?
Have you tried to do .Get()
Have you tried to do .Get() on specific instance?
valueOf() is the correct way. Next version will have .value accessor too (for unification)
danilo
Yes I tried .Get() on specific instance
Post by danilo »
Yes I did for example:
http://IP_OF_RAZBERRY:8083/ZWaveAPI/Run/devices[2].instances[2].commandClasses[0x31].Get()
response was: NULL
Then I did:
http://IP_OF_RAZBERRY:8083/ZWaveAPI/Run/devices[2].instances[2].commandClasses[0x31].data.val.valueOf(0)
response was: 0
The corrcet value should have been: 955 for 955W.
I only get the updated value after I update manually through your UI.
Can you give me a few example lines on how to correctly get the values out of the Aeon Labs HEM with JSON ?
Also if I want to constantly (every 10s) read the Aeon Labs HEM values and store the results in a file on the raspberry memory card, how do I proceed? Write a Python script and run it on the Raspberry?
Can you publish a sample code how to read Sensors on the RaZberry witrh a Python program?
Thanks, danilo
danilo
Problem solved - Aeon Labs HEM needs USB Power
Post by danilo »
Ok I got the problem solved.
I had to remove the batteries from the Aeon Labs HEM and run it with USB power then it started updating the data when I issued the Get() command.
How can I include the JSON comands into a script so I can log the sensor values every 5 seconds and store them in a file on the raspberry memory Card?
I would like to run that logging program (or script) directly on the raspberry so that I can turn it into a data logger. I will then periodically pick up the logged values remotely.
You can edit config.xml to
You can edit config.xml to change original automation/main.js by your file. This file can contains something like this:setInterval(function() {
zway.devices[N].instances[0].commandClasses[0x31].Get();
}, 10000);
zway.devices[N].instances[0].commandClasses[0x31].data.val.bind(function(){
var o = loadObject("meter_data_N");
o[new Date()] = this.value;
saveObject("meter_data_N", o);
