Control somfy rts shades
Posted: 25 Mar 2013 01:52
by VoD
I'm very interesting by this product but before buy it I have a question.
Today, I have somfy rts shades drived by a remote (a telis), is it possible to control directly my shades with the razberry without adding 3rd devices?
Thanks for your answer.
No
by pacaj2am
Telis is not z-wave compatile... I made my own using the remote controller.
Jan
Did you use Raspberry for
by pz1
Did you use Raspberry for that? I was planning to do the same as you did via some of the remaining GPIO pins plus some buffer electronics. I bought an extra remote for it already.
yes, raspberry and I had some
by pacaj2am
yes, raspberry and I had some spare optocouplers...
Hi Jan,
by VoD
Hi Jan,
What kind of optocoupler did you buy?
I found a howto (sry it is in french) http://www.planete-domotique.com/blog/2 ... que-tiers/
Is it this kind of assembly that you did? I think it's a little expensive...
Is there another solution to drive my shades using a raspberry?
this is pretty close. The gnd
by pacaj2am
this is pretty close. The gnd cable is just one sufficient. I bought just cheapest optocoupler. Led part is connected to raspberry. Transistor is attached to microswitch of buttons...
Thanks for the reply. I am
by pz1
Thanks for the reply. I am also looking for some effective rain and wind force guages to control the opening of my shades. The main screen is 3*4 meters. Wind force doesn't need to be precise; a binary thingy that says it is above or below Beaufort 6-7 would be fine. For rain I would like to detect the first drops that fall. I came across this one: http://www.rainsensors.com/ that seems to do that.
Pieter
Jan,
by VoD
Jan,
I'm a newbie in electronic... Do you have a schema, some photos or an howto?
My goal is to drive my somfy shades using a raspberry and keep place on it to drive other things like my garage door for example.
Safe to drive directly from GPIO?
by pz1
Can you drive the opto coupler led directly from the GPIO pins?
JS or Python
by pz1
Did you use JS or Python? I would appreciate if you were willing to share the code.
