list devices and get battery level
johnrswanton
Post by johnrswanton »
Hi all,
I have recently bought the raspberry pi and z-way module and got it set up no problems
I am currently able to get the state of a door sensor whether it is open or closed using the below url:
http://192.168.0.104:8083/ZWaveAPI/Run/ ... el.valueOf()
what i would like to do it get a list of all the devices that are connect to it and they status( online/offline) also i want to get the current battery level
regards
John
Please conslt the manual.
Use /ZWaveAPI/Data/0 to get the full tree.
johnrswanton
i can access the full tree from
http://rasp_ip:8083/ZWaveAPI/Data/0
I have one door sensor which has node id of 2 where do i find information on this device and other additional devices i add in the future
what part of the tree contains a list of all the devices and their node ids and also their current battery level
regards
John
Please check the Fib 8 on
Please check the Fib 8 on page 21 of the manual http://razberry.z-wave.me/docs/zway.pdf
It shows where is the list of all devices. New devices are added to the tree. There is a description how to get updates instead of full tree.
Check section Battery Command Class to see how to access battery level.
