OpenElec OS
Posted: 10 Apr 2013 09:50
by Isaksson
Hello.
have read in the manual that you support openelec os.
But the Bash script does not work (it tryes to write to openelec read only partition) I have talked to the guys over at openelec and its not possible to make that partition RW.
So my question is:
Do you have a installation script that is made for openelec os?
As answered by e-mail, we
As answered by e-mail, we have no install script yet. We hope Openelec team will make a plugin for our RaZberry. The problem is in the installation script.
The s/w itself was tested to work on Openelec distro.
Setup
by intothev01d
Are there instructions somewhere for getting this setup on Openelec since the install script won't work?
You need to unpack it and run
Autostart is different in OpenElec. This is something for you to check.
Also some libraries might need to be installed.
Installation
by ollfa
I'm currently running Openelec with Razberry. I have been running this setup for the last 2 months and its stable...
-From the storage folder in openelec run the "wget ..." command as specified in Razberry documentation and downlaod the razberry server.
-Download the following libs; libacl.so, libarchive.so, liblzma.so, liblzo2.so, libminilzo.so. Links:
http://us.mirror.archlinuxarm.org/armv6 ... pkg.tar.xz
-Get Libattr.so from somewhere, it can be found /lib on a Raspbian image.
-Put all lib files in libs/ folder of your downloaded zwave/razberry server, and export that folder.
-When you run setup script in razberry folder it will complain about missing libs. Link your downloaded libs to missing, if "libattr.so.1" is missing, "ln -s libattr.so libattr.so.1".
Good luck!
autostart
by ollfa
This script starts the z-way server on startup. It also exports the library path. In /storage/.config/autostart.sh paste the following. You may have to create that file.#!/bin/sh #Start z-wave-server export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/storage/.z-way-server/libs cd /storage/.z-way-server/ ./z-way-server &
Good news! You can write this
Good news! You can write this in a new thread like a HowTo and we will stick it to the top to allow other OpenElec users to use it.
