Possible Hardware Failure
Posted: 18 Apr 2013 05:02
I have been using my Razberry for about 2 weeks successfully. Yesterday is stopped controlling the one switch that I have set up. I tried a reboot, a shutdown, reseat the Razberry and reinstalling the z-way-server and I am still unable to pull up the page on :8083. Here is the last part of the log after reinstalling z-way-server. In assistance is appreciated.
[2013-04-17 21:55:59.410] Worker thread entry point
[2013-04-17 21:55:59.420] Adding job: Get controller info and supported function classes
[2013-04-17 21:55:59.423] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-04-17 21:55:59.603] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2013-04-17 21:55:59.615] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-04-17 21:55:59.795] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2013-04-17 21:55:59.807] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2013-04-17 21:55:59.987] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2013-04-17 21:55:59.987] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2013-04-17 21:55:59.988] Job 0x07 (Get controller info and supported function classes): fail
[2013-04-17 21:55:59.988] Get Serial API Capabilities returned zero.
[2013-04-17 21:55:59.988] Removing job: Get controller info and supported function classes
failed to discover ZWay: -9
Z-Way release 2013-03-29 02:09:39 +0400 5d3085259a6f9c9a3305d383d535be645c04bc5e
Starting Z-Way for device /dev/ttyAMA0...
