Razberry OpenRemote Integration
You'll find here the Integration Manual
OpenRemote is an Integration and Visualisation platform form home automation. There is free community version, and a paid for professional version. For Z-Wave, OpenRemote has a limited native Z-Wave implementation.
Openremote seems to me a nice complementary product to Razberry. It is relatively simple to configure good looking interfaces for Web browsers, IPhone/Ipad, Android.
After quite some time of learning and playing, I have found an integration approach that means simplicity for users. The integration is driven using the standard OpenRemote HTTP protocol. I do use the Z-Way API automation engine to hide the complexities for OpenRemote users.
I have summarised my experiences in the first 6 posts of this OpenRemote Forum thread
Sofar I only support single and dual binary switches, which have proven to work fine.
Thanks to the patient help provided by Serguei, and Marcus Redeker from OpenRemote I got this working.
Comments are appreciated either here or on the OR-forum.
OpenRemote-Razberry documentation
The official OpenRemote-Razberry integration document is available here:
http://www.openremote.org/display/docs/ ... h+Razberry
Pieter
Pitt13
hello,
Post by Pitt13 »
hello,
solution that interested me but I do not quite understand what to do.
I have not yet mastered the language linux.
Can you make a video of this solution with razberry?
My goal is to have an interface with login, creation stage, and an Android application with the same
Linux is not a language, but
Linux is not a language, but the operating system that runs on Raspberry Pi. What you must know about it is very basic. I.e. how to copy a file, and how to edit a line in an existing file. You'll definitely find something about that on the raspberry.org pages.
Here (http://www.youtube.com/user/openremote) are a number of videos to give you an impression on how to work with OpenRemote in general and with different protocols.
I'll review the instruction to see how I can make the installation of the RaZ-OR module simpler for users.
OpenRemote does have some login facilities, but I have not looked into those yet.
Creation is done in a cloud service called Designer. You there model your devices, and interfaces for Web, iPhone or Android. Straightforward control of devices is simple configuration work. Schedules and complex scenes have to be defined in a rather awkward rules editor, which ultimately may require moderate Java programming experience.
Pitt13
hello,
Post by Pitt13 »
hello,
sorry for my bad english, I'm french and I use Google translation to read: D
Yesterday I went to the / opt with Raspbian explore. I found the entire system and place to put the "Raz-or" module. If I understood the tutorial after your link OpenRemote is this module that will communicate with OpenRemote Designer and Android version.
The only thing that bothers me is that you mentioned "cloud service", but I want to stay local and outsource anything. Is this possible?
Thank you for the youtube link
Open remote is as the name
Open remote is as the name suggests open source, so you can download and install the sources of the free version on your own machine. I never bothered to do that, but some commercial parties that don't want to rely on external cloud services have gone that route. There are a few threads about that I beleive. It is also documented to some extent.
If you want to know more, search the OpenRemote User forum and other OR documents.
RaZ-OR activity on OpenRemote forum
There is quite some activity lately on the OpenRemote forum topic RaZ-OR thread . An example implementation is emerging where the OpenRemote controller is also running on the Raspberry. At the moment focus is on extending the RaZ-OR module.
Update tested with RaZ-OR module
I tested the RaZ-OR module with the new Razberry sw of 17-05-2013. It is up and running fine for an hour now. I added a paragraph about handling Razberry updates in the HowTo.
RaZ-OR Installation procudure updated
Please note that I have updated the RaZ-OR module installation on the OpenRemote site in response to the instructions of this article:
http://translate.google.ru/translate?hl ... F180749%2F
Their solution is better, simpler, and there is no more confusion for users.
Pitt13
OpenRemote on RPi = 0
Post by Pitt13 »
hello,
I followed the tutorial two, but nothing works.
It's been 10 days that I want a solution without finding one that works.
OpenRemote on RPi it does not work for me.
is what I miss some thing that is not in the tutorial?
