Solved; DLC not shown as thermostat + not able to get value
Posted: 13 May 2013 22:38
I have just received my Razberry module, connected it and installed the server software. After that I have included one of my Danfoss Living Connect valves but they do not appear as a thermostat device as they do in the cloud service. Nevertheless if I send the set command (example; http://192.168.0.178:8083/ZWaveAPI/Run/ ... .Set(1,13)) it works without any problem, on the opposite side if I send the Get command (example; http://192.168.0.178:8083/ZWaveAPI/Run/ ... [0x43].Get()) I only receive the value "null".
Pity that is exactly the reason why I bought the Razberry in the first place, reading the value via the cloud service is a hassle. You have to poll and analyse the stream of information; If you information is correct, with the Razberry you can just ask the value as the internal architecture of the server software is different.
It there a way to receive the actual set value?
SOLVED!!
Again I was to fast to ask a question; I should have used .data instead of .Get, I'm sorry.
Thank you
Bart
SOLVED!!
Thank you
Bart
