Can not read ZDDX (solved)
Posted: 18 May 2013 18:34
by pz1
Serguei,
With the new s/w from 2013-05-17 under menu Devices configuration I do get this error:
"Can not read ZDDX/5-0002-8005-0001-06-02-43-02-06.xml Not Found, Not Found"
This error did not occur immediately after s/w upgrade.
I noticed that I don not see the Expert commands either anymore. They were there after initial re-install.
I do get error method_defaultValue: unknown type of value
The only thing I had done on raspberry is making the adaptations for the Razberry-OpenRemote integration.
A reboot of Raspberry did not solve this problem
Pieter
Edit: I performed a 'forced re-interview' on all individual devices. That not only solved the ZDDX errors, but also made the Expert Commands come back.
Thanks for the tip. Will add
Thanks for the tip. Will add it to changelog as a notice. Indeed a re-cinlusion might be needed for some cases.
Still can't get DLC in Expert Commands
by pz1
I still can't get the DLC in the Expert Commands. Still get this error method_defaultValue: unknown type of value error. Doing forced re-interviews does not help. (I don't remember if it was visible the first time I fixed the ZDDX thing)
After each re-interview, the interview status was reported as complete!
I also notice the flashing antenna and alarm icons. These do apear within an hour after I have made the antenna stable with the middle end left button on the DLC.
Indeed. Fixed this. Will be
Indeed. Fixed this. Will be in new v1.3.1
