Switch not updating it's status when maually pressed
pacaj2am
Post by pacaj2am »
i have switch Everspring Wall Switch. When switch is manually pressed, i can see in server log some communication,
--switch goes to On
[2013-05-19 10:16:37.182] RECEIVED: ( 01 0F 00 49 84 0B 09 03 10 01 25 27 72 86 75 73 DD )
[2013-05-19 10:16:37.195] SENT ACK
[2013-05-19 10:16:37.196] Node info received: 11
[2013-05-19 10:16:37.197] SETDATA devices.11.data.basicType = 3 (0x00000003)
[2013-05-19 10:16:37.200] SETDATA devices.11.data.genericType = 16 (0x00000010)
[2013-05-19 10:16:37.201] SETDATA devices.11.data.specificType = 1 (0x00000001)
[2013-05-19 10:16:37.203] SETDATA devices.11.data.deviceTypeString = "Binary Power Switch"
[2013-05-19 10:16:37.205] SETDATA devices.11.data.nodeInfoFrame = byte[6]
( 25 27 72 86 75 73 )
[2013-05-19 10:16:37.213] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
--switch goes to off
[2013-05-19 10:16:38.228] RECEIVED: ( 01 0F 00 49 84 0B 09 03 10 01 25 27 72 86 75 73 DD )
[2013-05-19 10:16:38.241] SENT ACK
[2013-05-19 10:16:38.243] Node info received: 11
[2013-05-19 10:16:38.244] SETDATA devices.11.data.basicType = 3 (0x00000003)
[2013-05-19 10:16:38.245] SETDATA devices.11.data.genericType = 16 (0x00000010)
[2013-05-19 10:16:38.246] SETDATA devices.11.data.specificType = 1 (0x00000001)
[2013-05-19 10:16:38.250] SETDATA devices.11.data.deviceTypeString = "Binary Power Switch"
[2013-05-19 10:16:38.252] SETDATA devices.11.data.nodeInfoFrame = byte[6]
[2013-05-19 10:16:38.259] SETDATA devices.11.data.lastReceived = 0 (0x00000000)
but status of switch in server is not updated? Am I doing something wrong?
When i ask manually for update, i receive it correctly.
I assume "switch all" has no influence on this.
Thank you for your answer.
Jan
Your switch only sends NIF on
Your switch only sends NIF on button press. I suppose it should have some Association group to report the value on the controller. If no, you can use a trick to send Get on NIF:
zway.devices[11].data.nodeInfoFrame.bind(funtion() { zway.devices[11].SwitchBinary.Get() });
pacaj2am
what is association group?
Post by pacaj2am »
what is association group? How to configure?
I tried http://.../ZWaveAPI/zway.devices[11].data.nodeInfoFrame.bind(funtion(){zway.devices[11].SwitchBinary.Get()};
which returned
Not found
How to do the binding?
Thnak you
Jan
You need to use /JS/Run to
You need to use /JS/Run to use full JS syntax.
This device might have association groups in the Device Configuration tab. If not, you are unlucky - this device might be not able to report values. But as I remember, it should.
