Aeotec multisensor
johnrswanton
Aeotec multisensor
Post by johnrswanton »
Hi
I have a Aeotec Multisensor and i have incuded it RaZberry I'm able to get the value for the motion from this url : http://RASPBERRYPI_IP/ZWaveAPI/Run/devices[4].instances[0].commandClasses.SensorBinary.data.level.valueOf()
but i am unable to get the temperature,humidity and light sensor readings so how do i go about this, what url should i be using ?
please help
regards
John
Use SensorMultilevel.data[**]
Use SensorMultilevel.data[**].val.valueOf()
Try just SensorMultilevel.data to get the tree and see what ** should be
johnrswanton
Thanks for you reply,
i have tried
http://RASPBERRYPI_IP:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses.SensorMultilevel.data
and got this response
{"name":"devices.4.instances.0.commandClasses.49.data","updated":"1970-01-16T20:17:47.557Z","invalidated":"1970-01-16T20:17:47.556Z","version":{"name":"version","updated":"1970-01-16T20:17:47.647Z","invalidated":"1970-01-16T20:17:47.646Z"},"security":{"name":"security","updated":"1970-01-16T20:17:47.557Z","invalidated":"1970-01-16T20:17:47.556Z"},"interviewDone":{"name":"interviewDone","updated":"1970-01-16T20:17:47.647Z","invalidated":"1970-01-16T20:17:47.556Z"},"interviewCounter":{"name":"interviewCounter","updated":"1970-01-16T20:17:47.557Z","invalidated":"1970-01-16T20:17:47.556Z"},"sensorType":{"name":"sensorType","updated":"1970-01-16T20:21:47.673Z","invalidated":"1970-01-16T20:17:47.556Z"},"sensorTypeString":{"name":"sensorTypeString","updated":"1970-01-16T20:21:47.673Z","invalidated":"1970-01-16T20:17:47.556Z"},"val":{"name":"val","updated":"1970-01-16T20:21:47.673Z","invalidated":"1970-01-16T20:20:29.070Z"},"scale":{"name":"scale","updated":"1970-01-16T20:21:47.673Z","invalidated":"1970-01-16T20:17:47.556Z"},"scaleString":{"name":"scaleString","updated":"1970-01-16T20:21:47.673Z","invalidated":"1970-01-16T20:17:47.556Z"}}
when i tried
http://RASPBERRYPI_IP:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses.SensorMultilevel.data.val.valueOf()
I got a value of 21.5 does this mean it 21.5 degrees or is this really the temperature ?
regards
John
Use data.scaleString.valueOf(
Use data.scaleString.valueOf() to get the units. Looks like a reasonable temperature
johnrswanton
I have temperature but how do i get light and humidity values
Hi,I am able to get the temperature but it keeps jumping in value im not sure but maybe im getting the light and humidity but all on the same url as shown below, is there a way of seperating them?http://RASP_IP:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses.SensorMultilevel.data.val.valueOf()I have included links to screenshots of the control panel for the device in question, from the configuration it looks like it should give me all the values but just mainly the temperature. please help regards John
Pitt13
Hello
Post by Pitt13 »
Hello
http://IP_RPi:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses[49].data[1].val.value => for Temperature
http://IP_RPi:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses[49].data[3].val.value => for Lux
http://IP_RPi:8083/ZWaveAPI/Run/devices[4].instances[0].commandClasses[49].data[5].val.value => for Humidity
johnrswanton
Thanks,   well tried them
Thanks,   well tried them urls and got this error"Uncaught TypeError: Cannot read property 'val' of undefined"regards John
Pitt13
Post by Pitt13 »
my adjustment are :
wake up 10 minutes => yes
On time delay => 600
Unsolicitate reports interval timing for group 1 and 2 and 3 : 720
Wake up time => 600
Pitt13
My config : Device N°5
Post by Pitt13 »
{"name":"devices.5.instances.0.commandClasses.49.data","type":"NoneType","value":null,"updateTime":1368228278,"invalidateTime":1368228277,"version":{"name":"version","type":"int","value":5,"updateTime":1368228280,"invalidateTime":1368228278},"security":{"name":"security","type":"bool","value":false,"updateTime":1368228278,"invalidateTime":1368228277},"interviewDone":{"name":"interviewDone","type":"bool","value":true,"updateTime":1368228288,"invalidateTime":1368228277},"interviewCounter":{"name":"interviewCounter","type":"int","value":9,"updateTime":1368228286,"invalidateTime":1368228277},"1":{"name":"1","type":"NoneType","value":null,"updateTime":1370035837,"invalidateTime":1369676675,"sensorTypeString":{"name":"sensorTypeString","type":"str","value":"Temperature","updateTime":1368228287,"invalidateTime":1368228286},"val":{"name":"val","type":"float","value":19.899999618530273,"updateTime":1370035837,"invalidateTime":1368228286},"deviceScale":{"name":"deviceScale","type":"int","value":0,"updateTime":1370035837,"invalidateTime":1368228286},"scale":{"name":"scale","type":"int","value":0,"updateTime":1370035837,"invalidateTime":1368228286},"scaleString":{"name":"scaleString","type":"str","value":"°C","updateTime":1370035837,"invalidateTime":1368228286}},"3":{"name":"3","type":"NoneType","value":null,"updateTime":1370035837,"invalidateTime":1369676675,"sensorTypeString":{"name":"sensorTypeString","type":"str","value":"Luminiscence","updateTime":1368228287,"invalidateTime":1368228286},"val":{"name":"val","type":"float","value":201,"updateTime":1370035837,"invalidateTime":1368228286},"deviceScale":{"name":"deviceScale","type":"int","value":1,"updateTime":1370035837,"invalidateTime":1368228286},"scale":{"name":"scale","type":"int","value":1,"updateTime":1370035837,"invalidateTime":1368228286},"scaleString":{"name":"scaleString","type":"str","value":"Lux","updateTime":1370035837,"invalidateTime":1368228286}},"5":{"name":"5","type":"NoneType","value":null,"updateTime":1370035837,"invalidateTime":1369676675,"sensorTypeString":{"name":"sensorTypeString","type":"str","value":"Humidity","updateTime":1368228287,"invalidateTime":1368228286},"val":{"name":"val","type":"float","value":56,"updateTime":1370035837,"invalidateTime":1368228286},"deviceScale":{"name":"deviceScale","type":"int","value":0,"updateTime":1370035837,"invalidateTime":1368228286},"scale":{"name":"scale","type":"int","value":0,"updateTime":1370035837,"invalidateTime":1368228286},"scaleString":{"name":"scaleString","type":"str","value":"%","updateTime":1370035837,"invalidateTime":1368228286}}}
It seems you have old version
It seems you have old version of RaZberry (v1.1). Please use the new version (v1.2 or greater - latest is v1.3.1). You will need to force re-interview for that device.
