Translations xml files
Is my assumption correct that the xml files like scales, thermostatModes do directly reflect the Z-Wave standard? And as a consequence if I define a thermostat mode on the basis of this xml, my command is compatible with all thermostats that implement that mode.
No. All the XML files in
No. All the XML files in translation/ folder are used only to translate numeric values into strings. It does not influence the support of new modes at all.
