RaZberry no longer connection via HTTP
Henk Zwan
Post by Henk Zwan »
After installing Soft-float Debian "wheezy" , RaZberry no longer available via
http://IP_OF_RASPBERRY:8083. (Via Putty IP_OF_RASPBERRY is available).
With the first installation of Raspbian "wheezy" the Razberry works fine
Remark:
Raspbian "wheezy", file: 2013-05-25-wheezy-raspbian.zip (For starting users)
Soft-float Debian "wheezy", file: 2013-05-29-wheezy-armel.zip (For Oracle JVM)
This is what i did for the installation of RaZberry:
user@pwd ~ $ wget -q -O - http://razberry.z-wave.me/install | sudo bash
This is the result:
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
Previous Z-Way installation found
Stoping Z-Way
Stopping Z-Way: rm: cannot remove `/var/run/z-way-server.pid': No such file or
directory
done.
Making backup of previous version of Z-Way in /opt/z-way-server_2013-06-07-06-21-33
Getting Z-Way for Raspberry Pi
Copying settings
Creating Z-Way startup script
Adding to autostart
update-rc.d: using dependency based boot sequencing
Starting Z-Way
Starting Z-Way: done.
Can anyone help me?
Henk Zwan
Z-Way for RaZberry will not
Z-Way for RaZberry will not work with Soft-Float version of Raspbian due to different floating pointers definition. We are working on SoftFP version of Z-Way right now. We will publish two different releases next time: HardFP and SoftFP. Meanwhile please return back to HardFP version.
Henk Zwan
PoltoS,
Post by Henk Zwan »
PoltoS,
thank you very much for this information.
Are there other images (then from raspberry.org) that will work with Java SE for Embedded on the Raspberry PI?
HenkZwan
Can not help with Java, but Z
Can not help with Java, but Z-Way will com soon for soft fp
