Its possible to use this product with razberry?
http://aeotec.com/z-wave-home-energy-me ... tions.html
Or in the future?
Aeon Labs Smart Energy Meter
Should work out of the box
Well,...
... It does not work so well as there is still no pepperdb entry. However I was in contact with aeotec support and they sent me the tech specs. However I was not able to create a working ZDDX file for myself. However I would happily share the document with you if you tell me how (no attachements possible to post).
Cheers SnD
Cheers SnD
Information
SpamNein,
Can you send on my email, jonnes1@gmail.com ? How do you get information from energy meter? Can you get with razberry api?
Thanks,
Thanks,
You can send it on razberry
You can send it on razberry-at-z-wave.me. If there is not ZDDX record in P1 database, the device has certainyl not passed certification yet. This means it might not work out of the box, since RaZberry do not handle devices in a specific way, but just use Z-Wave protocol to speak them. So, if they break the protocol, RaZberry will not be able to handle such device.
This is the difference between RaZberry and all other gateway softwares: it does not need any prior info about the device to be able control it. ZDDX file is only needed to be able to list all Config parameters, show device name and photo and convert some numeric data into text data (that was taken from the manual), but this is optional.
