Problem including Connect Radio Central
HeKa
Post by HeKa »
I'm having problem including Connect Radio Central (from Schneider-Electric). This what I get in the log:
2013-06-23 08:58:57,315 Z-Wave.ERROR Callback received, but no corresponding job in queue. Continue operations as if it is in queue.
2013-06-23 08:58:57,314 Z-Wave.DEBUG RECEIVED: ( 01 07 00 4A 03 06 00 00 B7 )
2013-06-23 08:58:57,214 Z-Wave.DEBUG Removing job: Add/re-include node to network: Stop
2013-06-23 08:58:57,211 Z-Wave.DEBUG RECEIVED ACK
2013-06-23 08:58:57,063 Z-Wave.DEBUG SENDING (cb 0x00): ( 01 04 00 4A C5 74 )
2013-06-23 08:58:57,052 Z-Wave.DEBUG Removing job: Add/re-include node to network: Start
2013-06-23 08:58:57,052 Z-Wave.DEBUG Adding job: Add/re-include node to network: Stop
2013-06-23 08:58:57,051 Z-Wave.INFO Add/re-include node to network: Start: Failed
2013-06-23 08:58:57,049 Z-Wave.DEBUG RECEIVED: ( 01 07 00 4A 03 07 00 00 B6 )
2013-06-23 08:58:54,040 Z-Wave.INFO Add/re-include node to network: Start: Node found: node 0
2013-06-23 08:58:54,037 Z-Wave.DEBUG RECEIVED: ( 01 07 00 4A 03 02 00 00 B3 )
2013-06-23 08:58:49,293 Z-Wave.INFO Add/re-include node to network: Start: Ready to add - push button on the device to be added
2013-06-23 08:58:49,292 Z-Wave.DEBUG RECEIVED: ( 01 07 00 4A 03 01 00 00 B0 )
2013-06-23 08:58:49,233 Z-Wave.DEBUG RECEIVED ACK
2013-06-23 08:58:49,062 Z-Wave.DEBUG SENDING (cb 0x03): ( 01 05 00 4A C1 03 72 )
2013-06-23 08:58:49,059 Z-Wave.DEBUG Adding job: Add/re-include node to network: Start
It seams like the job 'Add/re-include node to network' is removed before the device has responded. I can see the text 'Waiting' on the display of the Connect Radio Central at least 10 seconds after the job is removed...
Regards,
Henrik
This looks like Z-Cloud logs,
This looks like Z-Cloud logs, not RaZberry. What is your stick SDK? there are problems with most Merten products, since they are _very_ old
