I've 2 HSM100-S3 Multi-Sensor devices, both temperature and luminescence are working as expected, but the motion detector is not working. In Z-Way controller demo site, both devices always showed "triggered" as they have detected movements, and never go into idle state. I turned Sensitivity down to 150, 100, 50 and 0, all showed the state as "triggered". Thanks in advance.
Help: HSM100-S3 Multi-Sensor always shows "triggered" state
no longer an issue
I had to set the "On time : Minutes" to 1 to the the value change, the default value was set at 20 mins.
Check out the manual for
Check out the manual for proper settings of motion sensor security lighting, sometimes it happens we often used to do all the settings and we feel that what ever we had done is correct but we left some points of connection,, just check it out!!
