GreenWave Reality - random Meter values
hekj
Post by hekj »
My GreenWave Realty switches reports random meter values in Z-Way v1.4-rc1 even if they have been turned off for several hours.
devices.13.data.deviceTypeString.value: "Binary Power Switch"
devices.13.data.manufacturerId.value: 153
devices.13.data.manufacturerProductType.value: 2
devices.13.data.manufacturerProductId.value: 2
devices.13.data.ZWLib.value: 3
devices.13.data.ZWProtocolMajor.value: 3
devices.13.data.ZWProtocolMinor.value: 33
devices.13.data.SDK.value: "6.01 pl2"
devices.13.data.applicationMajor.value: 4
devices.13.data.applicationMinor.value: 21
devices.13.data.nodeInfoFrame.value": [ 37, 50, 114, 134, 32, 113, 112, 39, 133, 135, 117, 86 ]
e.g.
devices.13.instances.0.commandClasses.32.name: "Basic"
devices.13.instances.0.commandClasses.32.data.level.value: 0
devices.13.instances.0.commandClasses.37.name: "SwitchBinary"
devices.13.instances.0.commandClasses.37.data.level.value: 0
devices.13.instances.0.commandClasses.50.name: "Meter"
devices.13.instances.0.commandClasses.50.data.2.sensorTypeString.value: "Electric "
devices.13.instances.0.commandClasses.50.data.2.val.value: 5145.6
devices.13.instances.0.commandClasses.50.data.2.scaleString.value: "W"
Henrik | http://nexahome.se
Please provie us the debug
Please provie us the debug log where we can see the wrong packet to come in
These values are correct. One
These values are correct. One is scale 0 (kWh), second scale is 2 (W). Where do you see them mixed? May be sone UI renders them wronlgy?
hekj
One Sensor value received
Post by hekj »
One Sensor value received from an other GreenWave Reality switch (6-port).1107558.375 W[2013-08-09 19:01:43.738] RECEIVED: ( 01 18 00 04 00 10 12 60 0D 01 01 32 02 21 34 00 A9 00 00 00 09 00 00 00 00 09 )[2013-08-09 19:01:43.739] SENT ACK[2013-08-09 19:01:43.739] SETDATA devices.16.data.lastReceived = 0 (0x00000000)[2013-08-09 19:01:43.740] SETDATA devices.16.instances.1.commandClasses.50.data.2.val = 1107558.375000[2013-08-09 19:01:43.740] SETDATA devices.16.instances.1.commandClasses.50.data.2.delta = 9 (0x00000009)[2013-08-09 19:01:43.740] SETDATA devices.16.instances.1.commandClasses.50.data.2.ratetype = 1 (0x00000001)[2013-08-09 19:01:43.740] SETDATA devices.16.instances.1.commandClasses.50.data.2.previous = 0.000000[2013-08-09 19:01:43.741] SETDATA devices.16.instances.1.commandClasses.50.data.2 = Empty--- EVENT: 2013-08-09T17:01:43.744Z 1376067704 zway.dataUpdate [16,1,50,2,1107558.375,null]--- EVENT: 2013-08-09T17:01:43.746Z 1376067704 metricUpdate.ZWayAutoDevice_16-1:2 ["level",1107558.375] Edit: Removed the kWh value
hekj
Another random value.
Post by hekj »
Another random value.[2013-08-18 22:47:05.742] RECEIVED: ( 01 18 00 04 00 02 12 60 0D 04 01 32 02 21 34 00 FF 00 00 00 09 00 00 00 00 48 )[2013-08-18 22:47:05.743] SENT ACK[2013-08-18 22:47:05.744] SETDATA devices.2.data.lastReceived = 0 (0x00000000)[2013-08-18 22:47:05.744] SETDATA devices.2.instances.4.commandClasses.50.data.2.val = 1671168.000000[2013-08-18 22:47:05.744] SETDATA devices.2.instances.4.commandClasses.50.data.2.delta = 9 (0x00000009)[2013-08-18 22:47:05.744] SETDATA devices.2.instances.4.commandClasses.50.data.2.ratetype = 1 (0x00000001)[2013-08-18 22:47:05.745] SETDATA devices.2.instances.4.commandClasses.50.data.2.previous = 0.000000[2013-08-18 22:47:05.745] SETDATA devices.2.instances.4.commandClasses.50.data.2 = Empty
this problm is fixed in the
this problm is fixed in the latest version
