WebUI Bug
gdrapp
WebUI Bug
Post by gdrapp »
My RaZberry is currently included as a secondary controller on my network while I'm testing to see if it will fit my needs. There are several places in the web UI that assume the RaZberry is node number 1, when in my case it is not.
Device Control -> Device Status - the list indicates node 1 is the RaZberry, when it is not. (It's node 44)
Device Configuration -> The first device in the list (node 1) is listed as the RazBerry, but this node is not the RaZberry.
Device Configuration -> Associations for each device list RaZberry for node 1 when it is not node 1.
How have you made RaZberry to
How have you made RaZberry to become ID=44? Who is node 1 in that case?
gdrapp
The RaZberry is node 44
Post by gdrapp »
The RaZberry is node 44 because I included it as a secondary controller in my existing zwave network. My Homeseer Z-Troller is my primary controller and is node 1 in my zwave network.
I got your problem! By
I got your problem! By default the only one name is set - name of device #1. You just need to change that name. In fact nothing relies on RaZberry to be node #1.
gdrapp
Ah thank you, that was it! I
Post by gdrapp »
Ah thank you, that was it! I don't know why but that wasn't obvious to me.
