Installation problems on RASPBMC
tukov
Post by tukov »
I have an RPI running RASPBMC, it seams inpossible to install z-way server.
I got following when I re-install, done 6 times now.. (I have rebooted and powered off, tried start/stop, tried to kill xbmc and start/stop of z-way server). It seams that it is impossible to start z-way server. When I try to start z-way server manually it stands that z-way server starts. But when I monitor active process I do not find z-way server and I cannot access demo UI at port 8083.
Any ideas?
Thanks!
We officially support
We officially support Raspbian wheezy. You can do all needed manually. Check the install script. You need to install libraries, prepare port (disable the default console on it) and put the script into startup.
