Page 1 of 3
Read value from XML document
Posted: 29 Aug 2013 20:19
by pz1
I am in the process of moving some elements of my Solar Energy monitor to RaZberry. This involves reading values from XML documents with JavaScript. Almost all tutorials on that topic take it from the webbrowser perspective. For this application I have to do it on the server side. My xml file is simple:
<response>
<power>1817</power>
<temp>50.2</temp>
<response>
Sofar I only found E4X as a potential solution, but that route seems to be deprecated.
Edit: In the meantime I found xmldoc by Nick Farina (http://nfarina.com/post/34302964969/a-l ... javascript). It looks as if it depends on node.js, but that does not become clear to me. It also mentions depency on Sax, but does desribe how. At least not for my novice eyes.
Is there somebody in this community who can give me a hint how to proceed?
Thanks,
Pieter
Got a partial solution
by pz1
With help of the guys of Stackoverflow I managed to get the xml element extraction working with the following bash script xmlparse.sh:
#!/bin/sh
# $1 is filename without .xml extension. $2 is tagname without surrounding brackets
grep -E -m 1 -o "<$2>(.*)</$2>" ./private/$1.xml | sed -e "s,.*<$2>\([^<]*\)</$2>.*,\1,g"
This script is stored in the automation subdirectory, the xml files are supposed to be in the ./private directory. Next I defined in the the Java script file my_openremote.js the following function:
GetxmlElement = function(file,tag) {
var test=system("/opt/z-way-server/automation/xmlparse.sh " + file + " " + tag);
return test;
Whereas the bash script nicely returns the power value of 1817, the js function if called from chrome:
http://raspberry_IP:8083/JS/Run/GetxmlElement("pvlogger","power")
does return [0,""], where I had expected [0,"1817"]
edit1:
1) I also get [0,""] if I only do the first part before the pipe.
2) If the bash script has only one line saying:
echo "abc"
I do get abc returned in the browser. So the overall mechanism seems to work OK.
edit2:
If I do change the script, to let echo the result:
#!/bin/sh
power=$(grep -E -m 1 -o "<$2>(.*)</$2>" ./private/$1.xml | sed -e "s,.*<$2>\([^<]*\)</$2>.*,\1,g")
echo $power
I do get [0,"
"], but not the value 1139 that the script returns on the commandline.
Apparantly I am overlooking something with the outputs of grep and sed
Any one out here who has a clue?
Re: Read value from XML document using system() call
Posted: 02 Jun 2014 11:48
by pz1
As this thread has shown sofar, I got stuck on parsing values from an XML file with earlier versions of Z-Way. The System() call obviously won't work
My source of solar production data is only available in a XML format like:
<response>
 <power>1817</power>
 <temp>50.2</temp>
<response>
I think the OpenWeather module looks like a suitable template to derive a virtual device for my solar logger.
Is there a XPath (or equivalent) function available to do the extraction?
Posted: 02 Jun 2014 12:09
by pofs
It it rather easy to do with ZXmlDocument (available since v1.5):
var doc = new ZXmlDocument("<response><power>1817</power><temp>50.2</temp></response>");
var result = [
  parseInt(doc.findOne("/response/power/text()")),
  parseFloat(doc.findOne("/response/temp/text()"))
Here's how your xml document looks like in JS:
Document model
Document model
Screen Shot 2014-06-02 at 13.06.06.png (52.74 KiB) Viewed 14625 times
Note that if you request data with http.request(), and response (or enforced) mime type is xml (application/xml, text/xml etc.), then result will be automatically parsed into ZXmlDocument. You'll just need to fetch required values.
Posted: 02 Jun 2014 12:43
by pz1
pofs wrote: Note that if you request data with http.request(), and response (or enforced) mime type is xml (application/xml, text/xml etc.)
Thank you for the quick response. I remember PoltoS mentioned it to me, but I lost it, because I did not understand it at the time. I am doing a crash course on learning this more advanced JS, GiT etc. So please be gentle.
Actually I have to fetch the the xml every 5 minutes or so from the pvlogger with url
http://pvlogger/status.xml. I am not a trained programmer so I have one more question at the moment.
In the example the xml is pasted directly in the code. How does the code change if I read from the url?
PS: the complete XML is shown below. For the moment I'll only use gauge_power and energy_today
<response>
 <gauge_power>827</gauge_power>
 <gauge_temp>39.4</gauge_temp>
 <gauge_vpv>279.0</gauge_vpv>
 <gauge_iac>3.7</gauge_iac>
 <energy_today>3.196</energy_today>
 <energy_total>5822.8</energy_total>
 <hours_total>7911</hours_total>
 <time_stamp>20140602 11:29</time_stamp>
</response
Posted: 02 Jun 2014 12:56
by pofs
Something like:
http.request({
    url: "http://pvlogger/status.xml",
    method: "GET",
    async: true,
    success: function(response) {
        if (response.parseError) {
            console.log("failed to parse data: " + response.parseError);
            return;
        var doc = response.data; // it is already ZXmlDocument
        var gauge_power = parseFloat(doc.findOne("/response/gauge_power/text()"));
        var energy_today = parseFloat(doc.findOne("/response/energy_today/text()"));
        console.log(gauge_power, energy_today);
    error: function(response) {
        console.log("failed to fetch data: " + response.statusText);
Cron-related code might be taken from BatteryPolling module.
Posted: 02 Jun 2014 13:45
by pz1
Thanks, I'll try this later today or tomorrow.
For my understanding: Don't I have to mention the mime type somewhere? The xml that I receive from the device is plainly as I posted it. They even didn't add a minimal XML header:
<?xml version="1.0" encoding="UTF-8"?>
EDIT 2015-01-12: The latest version of my PVlogger software does add this xml header now
Posted: 02 Jun 2014 13:58
by pofs
In most cases it will be returned by server, so there's no need to specify it.
For those rare cases when content type is not returned (or returned incorrectly), you may add
contentType: "text/xml"
to the request.
XML header is not required.
Re: Read value from XML document (PVLogger module)
Posted: 26 Feb 2015 13:57
by pz1
pofs wrote:02 Jun 2014 11:56
Something like:
http.request({
    method: "GET",
    async: true,
            return;
Sorry, a bit late with my response :D
I merged this code with the framework of the OpenWeather module, to create virtual devices that I can re-use elsewhere:
// --- Module methods
PVLogger.prototype.fetchSolar = function (instance) {
	var self = instance;
	http.request({
		url : self.config.url,
		method : "GET",
		async : true,
		success : function (response) {
			try {
				self.vDev.set("metrics:level", gauge_power);
				self.vDev.set("metrics:energy", energy_today);
			} catch (e) {
				self.controller.addNotification("error", "Can not parse Solar information", "module");
		error : function () {
// The following line is commented, because the logger is not available at night. Uncomment for initial testing.
//			self.controller.addNotification("error", "Can not fetch Solar information", "module");
The values for power and energy are correctly written to the log file. Sofar so good for the XML parsing!
>>>> edit 20150226:1457 Made a mistake. Edited post from here <<<<
Unfortunately, something seems to go wrong with the Virtual Device creation.
http://rasp_IP:8083/JS/Run/controller.devices.get("PVLogger_17").get("metrics")
produces
 {"scaleTitle":"W","title":"Solar Power","probeTitle":"Watt","gauge_power":473,"energy_today":0.548,"power":614,"energy":5}
I am surprised by getting the sensors twice, and with different values. I did not expect to get gauge_power and energy_today
Full code of index.js, and module.json are in the attached ZIP (REmoved)
Posted: 27 Feb 2015 14:23
by pz1
pz1 wrote: Unfortunately, something seems to go wrong with the Virtual Device creation.
produces
After upgrade to 2.0.1 RC16 I do get as expected:
{"scaleTitle":"W","title":"Solar Power","probeTitle":"Watt","level":2797,"energy":4.6}
