not able to re include devices
carvals
Post by carvals »
I included 3 fibaro devices (relay dimmer and led) it worked like a charm (except for the led one not yet implemented), then started to work on the UI and then tested the exclusion process and now I am not able to re-include my devices. I reset the controller and follow the process on the device itself to reset it (long press, 3 short press, 6 etc...)
Did I miss something?? maybe a cache somewhere needs to be clean?? I even re image the raspberry in case of software issue but if the cache is on the razberry it, how can I go back to factory default?? without using the reset function on the standard UI? Any advice would help.
Thanks in advance
cheers
Try to exclude devices first
Try to exclude devices first (even if they are already excluded).
If this does not help, try to reset the controller (RaZberry).
