Everspring wallplug dimmer does not update status
Posted: 13 Sep 2013 14:32
I have one Z-wave Everspring wallplug dimmer that dopes not update it's status in Z-way. I control the devices using Domoticz. For example if I switch it on the web-gui still says it is off. Only if I go to the z-way user interface and press the update button for the device the status updates. Anyone has an idea of why it bahaves like this?
Is there a http/Json command that can update the status of the device? Then I could create a job that updates the status every 10 minutes or so.
Thank you!
/H
Thank you!
/H
