Add support for the Fibaro FGD211 version 2.2
Holland
Post by Holland »
Kind request. In the upcoming release, support for the Fibaro FGD211 version 2.2 will be appreciated.
I have version 2.2 of this dimmer, and I can't select it from the menu: Select Device Description Record.
I believe that firmware updating is the main new feature in version 2.2
Running version 1.4
The ZDDX file does not really
The ZDDX file does not really matters except for configuration params descriptions and association names.
Since these have not changed from 1.9 version of the dimmer, you can use older ZDDX record.
