RaZberry to USB/Serial adapter
Posted: 27 Oct 2013 10:50
by mgb
So I just got my RaZberry daughter board and started playing around with it and so far so good. However, the hardware limitations of the RPi make dev work slow. Is it possible to connect the RaZberry daughter board (or RPi + RaZberry) to a Linux box and access it via a USB-to-Serial interface? This way I could dev on the Linux box and run my production on the RPi itself.
Thanks!
--mgb
Yes, you can connect RaZberry
Yes, you can connect RaZberry via USB-to-Serial converter, but you need to do it yourself.
So using something like this:
by mgbowman
So using something like this: https://www.sparkfun.com/products/718
It appears the Z-Wave chip is using 3V3 and the 5V GPIO Rasperry pins are unused. So it would seem I would simply need to wire up the 3V3 (P1), GND (P6), TXD (P8), RXD (P10) from the RaZberry to the appropriate pins on the USB breakout board. Can you confirm?
Thanks!
--mgb
Confirmed!
Confirmed!
Why to do this? We are releasing soon the USB adapter compatible with Z-Way for Raspberry Pi, Windows and Linux x86
Because I can and you haven't
by mgbowman
Because I can and you haven't released the USB adapter yet! :)
Like I said, I would like to develop on my workstation instead of the RPi so I was looking for a way to attach the RaZberry daughter board via USB and access it as a serial port.
