SUC/SIS support?
galmok
SUC/SIS support?
Post by galmok »
I am wondering if we could get access to a firmware that has SUC/SIS support? We are using the serial api directly and need to use Danfoss Living Connect Z thermostats (and they require SUC to function). As far as we can determine, the current firmware in the razberry does not have SUC but the documentation leads us to believe is does have it. We have tried to enable SUC in the firmware, but it doesn't work (probably as it isn't present).
Maybe you have a firmware that has SUC and explorer frames?
Can we put in a standard firmware and will it work on this board? We do not require the host software stack as we talk directly to the z-wave chip via the serial api.
If you don't need Z-Way s/w,
If you don't need Z-Way s/w, you can use any f/w (including original by Sigma).
There are SUC/SIS with Explorer Frames, but without FLiS support. We believe FLiRS is very important for nea future.
Please describe your task in detail by mail, and we will answer you sortly
