Lock events at /ZWaveAPI/Data/ ?
jkebinger
Post by jkebinger »
When I unlock my door (from the inside latch) all that is present in the list of events at /ZWaveAPI/Data/ is shown below. It looks like just the equivalent of a ping rather than any status about the lock state changing.
Why isn't the lock state reflected here?
devices.2.data.lastSend: {
value: 2864253,
type: "int",
invalidateTime: 1383016997,
updateTime: 1383049197
devices.2.data.lastReceived: {
value: 0,
type: "int",
invalidateTime: 1373210765,
updateTime: 1383049218
Can you show the log during
Can you show the log during opening it? If the device send us nothing, we can do nothing on our side. Are you sure to have RaZberry in association groups.
jkebinger
Here's the logs
Post by jkebinger »
I unlocked and locked the deadbolt, generating the logs below, but the tree was not updated beyond this:
devices.4.data.lastSend: {
value: 736208,
type: "int",
invalidateTime: 1383486642,
updateTime: 1383494925
devices.4.data.lastReceived: {
value: 0,
type: "int",
invalidateTime: 1383428378,
updateTime: 1383494935
[2013-11-03 11:00:41.563] RECEIVED: ( 01 08 00 04 00 04 02 98 40 2D )
[2013-11-03 11:00:41.565] SENT ACK
[2013-11-03 11:00:41.566] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2013-11-03 11:00:41.567] Node 4:0 CC Security: sending Nonce Report
[2013-11-03 11:00:41.568] Adding job: Nonce report
[2013-11-03 11:00:41.580] SENDING (cb 0x05): ( 01 11 00 13 04 0A 98 80 49 0A 23 BA E8 2D E5 09 05 05 18 )
[2013-11-03 11:00:41.592] RECEIVED ACK
[2013-11-03 11:00:41.603] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-11-03 11:00:41.604] SENT ACK
[2013-11-03 11:00:41.605] Delivered to Z-Wave stack
[2013-11-03 11:00:42.764] RECEIVED: ( 01 05 00 13 05 00 EC )
[2013-11-03 11:00:42.765] SENT ACK
[2013-11-03 11:00:42.766] Job 0x13 (Nonce report): Delivered
[2013-11-03 11:00:42.767] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2013-11-03 11:00:42.768] SETDATA devices.4.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2013-11-03 11:00:42.769] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 1161 (0x00000489)
[2013-11-03 11:00:42.770] SETDATA devices.4.data.lastPacketInfo = **********
[2013-11-03 11:00:42.771] SendData Response with callback 0x05 received: received by recipient
[2013-11-03 11:00:42.772] SETDATA devices.4.data.lastSend = 693402 (0x000a949a)
[2013-11-03 11:00:42.773] Job 0x13 (Nonce report): success
[2013-11-03 11:00:42.774] Removing job: Nonce report
[2013-11-03 11:00:42.785] RECEIVED: ( 01 1E 00 04 00 04 18 98 81 FF 1E 2C 9F 39 39 6B B5 3B 19 95 58 1A 49 CC 27 37 93 6F 9F E1 AB 25 )
[2013-11-03 11:00:42.786] SENT ACK
[2013-11-03 11:00:42.787] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2013-11-03 11:00:42.788] Node 4:0 CC Security: Received a secure message
[2013-11-03 11:00:42.789] SETDATA devices.4.instances.0.commandClasses.152.data.firstPart = **********
[2013-11-03 11:00:42.789] Node 4:0 CC Security: passing decrypted packet to application level: [ 71 05 15 01 ]
[2013-11-03 11:00:42.790] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.type = 21 (0x00000015)
[2013-11-03 11:00:42.791] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2013-11-03 11:00:42.792] SETDATA devices.4.instances.0.commandClasses.113.data.V1event = Empty
[2013-11-03 11:01:01.659] Job 0x13: deleted from queue
[2013-11-03 11:08:43.941] RECEIVED: ( 01 08 00 04 00 04 02 98 40 2D )
[2013-11-03 11:08:43.942] SENT ACK
[2013-11-03 11:08:43.943] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2013-11-03 11:08:43.944] Node 4:0 CC Security: sending Nonce Report
[2013-11-03 11:08:43.945] Adding job: Nonce report
[2013-11-03 11:08:43.946] SENDING (cb 0x06): ( 01 11 00 13 04 0A 98 80 9F 25 C8 74 F7 AF E5 B7 05 06 E4 )
[2013-11-03 11:08:43.957] RECEIVED ACK
[2013-11-03 11:08:43.969] RECEIVED: ( 01 04 01 13 01 E8 )
[2013-11-03 11:08:43.970] SENT ACK
[2013-11-03 11:08:43.971] Delivered to Z-Wave stack
[2013-11-03 11:08:45.121] RECEIVED: ( 01 05 00 13 06 00 EF )
[2013-11-03 11:08:45.123] SENT ACK
[2013-11-03 11:08:45.124] Job 0x13 (Nonce report): Delivered
[2013-11-03 11:08:45.124] SETDATA devices.4.data.lastPacketInfo.delivered = True
[2013-11-03 11:08:45.125] SETDATA devices.4.data.lastPacketInfo.packetLength = 13 (0x0000000d)
[2013-11-03 11:08:45.126] SETDATA devices.4.data.lastPacketInfo.deliveryTime = 1153 (0x00000481)
[2013-11-03 11:08:45.127] SETDATA devices.4.data.lastPacketInfo = **********
[2013-11-03 11:08:45.128] SendData Response with callback 0x06 received: received by recipient
[2013-11-03 11:08:45.130] SETDATA devices.4.data.lastSend = 736208 (0x000b3bd0)
[2013-11-03 11:08:45.131] Job 0x13 (Nonce report): success
[2013-11-03 11:08:45.132] Removing job: Nonce report
[2013-11-03 11:08:45.142] RECEIVED: ( 01 1E 00 04 00 04 18 98 81 66 8C 1D 5F FD BF C1 8F 03 E1 DD 49 BE 9F 21 38 12 F3 40 B3 2E F4 C2 )
[2013-11-03 11:08:45.143] SENT ACK
[2013-11-03 11:08:45.144] SETDATA devices.4.data.lastReceived = 0 (0x00000000)
[2013-11-03 11:08:45.145] Node 4:0 CC Security: Received a secure message
[2013-11-03 11:08:45.146] SETDATA devices.4.instances.0.commandClasses.152.data.firstPart = **********
[2013-11-03 11:08:45.146] Node 4:0 CC Security: passing decrypted packet to application level: [ 71 05 15 01 ]
[2013-11-03 11:08:45.147] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.type = 21 (0x00000015)
[2013-11-03 11:08:45.148] SETDATA devices.4.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2013-11-03 11:08:45.148] SETDATA devices.4.instances.0.commandClasses.113.data.V1event = Empty
[2013-11-03 11:09:04.033] Job 0x13: deleted from queue
The Alarm data is updated
The Alarm data is updated (seen in the log), but not propagated to the UI, since this Command Class is snot supported by the device, but controlled. But you can request it explicitelly via direct URL.
We will allow soon controlled CCs propagation too
