since my last raspberry system (raspbian) upgrade/update, rpi firmware update and change to java 7, my z-way server won´t start anymore.
I´m getting this text:
Z-Way version v1.4.1-rc1 from 2013-10-21 03:49:05 +0400 (build eeafaa52efb63177d7d96a3b68a614ab447662f1)
Starting HTTP server on port 8083...
Illegal instruction
I tried to install z-way again, but that didn´t helped.
z-way.log:
[2013-11-15 23:03:20.968] RECEIVED ACK
[2013-11-15 23:03:20.979] RECEIVED: ( 01 04 01 05 08 F7 )
[2013-11-15 23:03:20.980] SENT ACK
[2013-11-15 23:03:20.980] SETDATA controller.data.isPrimary = True
[2013-11-15 23:03:20.980] SETDATA controller.data.isInOthersNetwork = False
[2013-11-15 23:03:20.980] SETDATA controller.data.SISPresent = False
[2013-11-15 23:03:20.980] SETDATA controller.data.isRealPrimary = True
[2013-11-15 23:03:20.981] SETDATA controller.data.isSUC = False
[2013-11-15 23:03:20.981] Job 0x05 (Get controller capabilities): success
[2013-11-15 23:03:20.981] Error returned from zway_fc_enable_suc(zway, TRUE, TR$
[2013-11-15 23:03:20.982] Adding job: Set new SUC/SIS
[2013-11-15 23:03:20.982] Removing job: Get controller capabilities
[2013-11-15 23:03:20.994] SENDING (cb 0x01): ( 01 07 00 54 01 01 00 01 AD )
[2013-11-15 23:03:21.004] RECEIVED ACK
[2013-11-15 23:03:21.015] RECEIVED: ( 01 04 01 54 00 AE )
[2013-11-15 23:03:21.016] SENT ACK
[2013-11-15 23:03:21.016] Job 0x54 (Set new SUC/SIS): Failed
[2013-11-15 23:03:21.016] Job 0x54 (Set new SUC/SIS): fail
[2013-11-15 23:03:21.016] Removing job: Set new SUC/SIS
Some more information:
root@raspberrypi:/opt/z-way-server# file /bin/ls
/bin/ls: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, BuildID[sha1]=0x7f981e03f231371c5feaaeab28d9e23639e57cd3, stripped
root@raspberrypi:/opt/z-way-server# file /opt/z-way-server/z-way-server
/opt/z-way-server/z-way-server: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 3.6.3, not stripped
can anyone help me?
server start failure "illegal instruction"
can be resolved by going back to older kernel version.
You can fix this by going back to an older kernel version. I went back quite some, but doing this:
rpi-update 8234d5148aded657760e9ecd622f324d140ae891
You can find the different versions here:
https://github.com/Hexxeh/rpi-firmware/commits/master
thunderbolt
problem solved
thanks a lot, that solution fixed my problem.
maybe this should stand at the install instruction
still doesnt work
Please let me know exactly how you did to fix this? I have same problem but I cannot write rpi-update in terminal?
OpenELEC:~ # rpi-update 8234d5148aded657760e9ecd622f324d140ae891
-sh: rpi-update: not found
thunderbolt
you have to setuo the rpi
you have to setup the rpi update script first.
sudo apt-get update
sudo apt-get install git
sudo wget https://raw.github.com/Hexxeh/rpi-updat ... rpi-update -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update
sudo rpi-update
(in our case rpi-update 8234d5148aded657760e9ecd622f324d140ae891)
sudo reboot
sudo apt-get update
sudo rpi-update
sudo reboot
May be this is hardfp/softfp
May be this is hardfp/softfp problems? Which versio do you use?
