Trouble Connecting Intermatic HA05C
dailyinvention
Post by dailyinvention »
I'm very new to my Razberry and I am trying to connect a Intermatic HA05C Home Settings Screw In Module (http://amzn.to/1h0U581). I've had trouble adding the device using Razberry software. It seems to detect the device when I power the module on, but then it fails in the debugger. Is there something silly I'm not doing correctly.
I tried to check the zway-server.log file and it's empty. Is there also some way I can troubleshoot the issue better?
Any help is appreciated.
Stefan
Turn on logging in config.xml
Turn on logging in config.xml (level 0) and describe your problem better, please
