How do I setup the demo ui as defalut page?
etrust
Post by etrust »
Hi Forum,
If I access http://myrazberryip:8083 so I see there links to access demo ui and 3 more links.
My goal is: If I go to http://myrazberryip:8083, than I want to see directly the demo ui (jquerymobile).
What and where can I setup this exactly?
Re: How do I setup the demo ui as defalut page?
Did you mean to get at: http://raspberry:8083/jqmobile/
etrust
Post by etrust »
pz1 wrote:Did you mean to get at: http://raspberry:8083/jqmobile/
yes exactly, where should i put that?
cruxx
Post by cruxx »
change the config option in /opt/z-way-server/config.xml
orig: <http-root-dir>./htdocs</http-root-dir>
your wish: <http-root-dir>./htdocs/jqmobile</http-root-dir>
restart the z-way-server: sudo service Z-Way restart
maybe there is an error on the page like "read_error rules.xml"
copy the link ~config from /opt/z-way-server/htdocs/~config to /opt/z-way-server/htdocs/jqmobile/~config
Be sure - you have to do that after every update/upgrade of z-way version
cheers,
cruxx
