Thanks. I did try 1, (which is what i was using with openzwave on DomotiGa), however the UI does not update when the wall switch is used. so it seems razberry does not do a poll on the notification.
Update: It looks like my original issues of not seeing the parameters stemmed from the fact that the dimmer was not fully identified by zway (my fault as a new user).
Once I manually selected the device description record, the screen exposed the parameters on this screen...so no need to go into expert mode to change the params. (with the param 80 set to 2).
A case of rtfm
http://razberry.z-wave.me/docs/zwayUse.pdf
6.2 Select Z-Wave Device Description Record
After a successful inclusion Z-Way will interview the device to gather further information.
6.2.1 Select Device Description Record
Certain information such as names of association group, the brand name of the device and the
parameters of further conguration values can not be detected during interview. Z-Way uses a
device database with product description les to obtain this information. In order to identify the
right device description record certain parameters of the interview are used. If these parameters
match exactly one device description record this very record is loaded and its content is shown
on the device conguration page automatically.
If the information from the device is sucient to select one specic record from the database
this section of the tab is hidden. If it is not possible to identify the correct device description
record the user can manually choose the correct record. It is also possible to manually change
the selection of the device description by unhiding this section and clicking on the Select Device
Description Record button.
I still have the issue of the dimmer not reporting the final dim vale (ie 3%) when turned on via the gui.
Looking at the que commands, you can see it does the Set and then immediately a Get. Then no other Get's...as a result, the Get shows the dimmer value part way through it's dim cycle. It needs to do another Get.
EDIT2: Using this guide here
http://www.domotiga.nl/projects/domotig ... e_RaZberry
I was able to create an automation script that calls a .js and a .sh to send a jsonrpc call to DomotiGa (which then polls the zwave devices) whenever the light changes.
Getting closer.
