problem with device
Posted: 17 Mar 2014 01:46
by Zetat
I have only one Fibaro RGBW connected to the razberry.
It worked fine until I unplugged the power. Then the time change and it says the device seems to be dead.
I have tried reboot, reboot the chip.
Recently I removed the device from Razberry by using remove failed node. and I try to include it but it didn't find anything. And I wonder if it maybe is something wrong with the chip/fibaro or something else?
Re: problem with device
Posted: 17 Mar 2014 13:54
by nickasimir
Hi Zetat,
I have same problem with my fibaro module FGD211 dimmer.
I successfully connected the module 4 hours straight only and after same message "The device seems to be dead".
I have tested with domoticz too and same problem....
Zetat, di you try to exclude the device and re-included it ?
Regards,
Nicka
Posted: 17 Mar 2014 14:27
by Zetat
Zetat wrote:I have only one Fibaro RGBW connected to the razberry.
Yest I have delete it, but know I can't re-include it razberryn doesn't find it. (it's about 5 meters between them and no wall)
Posted: 17 Mar 2014 14:34
by nickasimir
try to re-include your module and push 3 time quickly on the module.
If that don't work push long time one time for reset module and re-include it.
Posted: 17 Mar 2014 15:20
by michap
RESET:
1. Disconnect voltage supply.
2. Press and hold the B-button located inside Fibaro RGBW Controller's casing.
3. Connect voltage supply still holding the B-button.
4. Release the B-button.
5. B channel will turn on (blue channel).
6. Disconnect power supply
Reinclude - maybe the distance (5meters) is too large... try with smaller distance...
Have you tried to include without any sensor/device at input?
Michael
Posted: 17 Mar 2014 20:12
by ollfa
I had a dimmer, not fibaro, which was reported as failed. It was a "build in"(no wall plug) dimmer for a 2-wire system. After some investigation I figured out the problem, the light bulb was broken... Because it was a 2-wire system the dimmer does not get any power if the bulb goes out.
