FGS 211 Parameters appear not editable
Posted: 20 Mar 2014 12:11
by hpd
I have an issue with the blue UI and device configuration for Fibaro FGS 211 V2.1 Switches:
In Configurations Section most parameters, eg 1-5, 13-33 and furthers show only the parameter name but have no Radio Button, sliders nor ediable value fields.
Instead of this following Text appears: Configuration paramter type is not handled in the Interface: constant
As a result of this I can not set most of the parameters of this switch.
Is there anything I can do to change this behaviour?
I am using v1.5.0-rc3 with razberry.
Re: FGS 211 Parameters appear not editable
Posted: 24 Mar 2014 23:23
by hpd
... Nobody providing Support in this forum?
Posted: 25 Mar 2014 11:53
by Eric
I had the same problem with another Fibaro module. It seems that in the Pepper One database a lot of configuration parameters are set to type constant. What I did was just edit the XML file (in your case that would be ZDDX/336-010f-0400-0103-03-03-14-01-03.xml) and search-and-replace type="constant" with type="range".
Posted: 25 Mar 2014 18:26
by hpd
Thanks Eric,
your hint solved the problem.
For others, having the same problem, I want to add, that 336-010f-0400-0103-03-03-14-01-03.xml does not properly describe all parameters. For FGS-2xx V2.1 Devices Parameter 3 & 4 have considerably changed. But the good news ist, this can all be customized using Erics hint.
Posted: 30 Mar 2014 12:40
Please choose another XML that describes the device better. May be PepperOne DB record for new devices is wrong. We will check it
Posted: 18 Nov 2014 17:57
by hpd
I am wondering why the the errounous FGS 211 FGS221 XML Files after more than 6 months are still not corrected in the Pepper One DB. If you let me know who is resonsible for this, I am happy to sent them a note about that problem.
Posted: 09 Dec 2014 11:17
Send it to us on info@ or to PepperOne
Posted: 12 Dec 2014 23:54
by Bwired
yes please update this
Posted: 14 Dec 2014 19:25
by hpd
Fibaro Switch ZDDX files have considerably improved now.
I found only a minor glitch with parameter 4 & 5 (automated turn off time) which should not be rangemapped.
Posted: 14 Dec 2014 19:42
by janw
Hmm. The editing worked fine under 1.7.2, but after upgrade to 2.0.0, it has no longer a picture, only
the `switch all' setting and it shows a miserious "fw_update" field. I'm still pretty new to all this stuff.
Should I do anything after upgrading to 2.0.0? Other functionality seemed to keep working just fine.
Seems my 1.7.2 --> 2.0.0 was a bit `half'. After a cold reboot of the Raspberry (unplug, re-plug power)
and selecting the proper device description, everything seems to be mostly working. Sorry for the noise.
Decided not to delete this post as it may help others to consider a full reboot after upgrading.
