during all my trials with Z-Way I have included and excluded more times the same device (Fibaro Plug).
At the end now I have 3 devices but only one is a real one.
How I can remove the 'false' devices?
thanks
Cancell Device
Cancell Device
- Presentazione1.jpg (30.3 KiB) Viewed 8780 times
Re: Cancell Device
Probably, in network section, reset the controller and reinclude all the devices.
Re: Cancell Device
If they are marked as failed or dead by the system you remove failed nodes under "network management".
Re: Cancell Device
It seems I cannot select "Remove Failed Node"
- 1.jpg (41.55 KiB) Viewed 8705 times
Re: Cancell Device
You need first to enable Expert mode and in Device Status tab press Test Connection button. Then go to Network Management and Remove them as Failed.
Re: Cancell Device
Please see attached the situation on Device 2 (one of the ones that I would like to remove).
I'm in Expert mode.
I'm in Expert mode.
- Presentazione standard2.jpg (36.96 KiB) Viewed 8663 times
- Presentazione standard1.jpg (51.89 KiB) Viewed 8663 times
Re: Cancell Device
have you tried this?
Michael
It is not possible that the same device is online with different IDsPoltoS wrote:You need first to enable Expert mode and in Device Status tab press Test Connection button. Then go to Network Management and Remove them as Failed.
Michael
