Page 1 of 2
C Sample....really exhausted !!
Posted: 25 Apr 2014 00:38
by gilpel
I want on my Raspberry to perform local actions when a remote device change status (send SMS, email). According to my understanding, this can be done only with C API.
So, I spent few hours trying to compile the z-way-test C sample without any success !
I can't understand why the LIB directory into the Makefile is uncorrect while z-way-server install path is static. Same regarding availability of .a lib refrence which doesn't exist. I didn't success to find out the Makefile modifications in order to perform the compilation.
I also didn't find any documentation about C API (e.g. binding). I read on the forum that it should be available "soon" (more than 6 months ago) !!
I'm very disapointed by the lake of support and documentation. This is not acceptable ยง
I'm quite close to decide to resign and abandon Razberry !
If anyone could help me to progress and send some examples or doc....
Re: C Sample....really exhausted !!
Posted: 25 Apr 2014 05:15
by pofs
Why do you think so? JS automation API (inside z-way-server) allows you to do pretty much the same as C API, plus some extra HTTP/XML/JSON operations and shell script invocation. You may implement what you need either as a custom JS script (and add its invocation to main.js), or even as a widget in a new Home Automation UI. Also I believe there's already a widget for SMS/email notification present in current HA.
I believe there's no "z-way-test" sample inside RaZberry distro. Where did you get it from? Probably the makefile is just invalid.
Also take a look at
http://yetanotherdeveloperblog.blogspot.be. The author did a great research about using z-way C library, and there are samples present.
EDIT: Oh, I've found z-way-test, and its makefile is just not intended for RaZberry environment. It should be something like this (but I haven't actually tested it):
### Variables ###
TARGET = z-way-test
ZWAY_LIB = libzway
ZWAY_LIB_DIR = /opt/z-way-server/libs
ZWAY_INCLUDE_DIR = /opt/z-way-server/libzway-dev
OBJECTS = $(patsubst %.c,%.o,$(wildcard *.c))
INCLUDES = -I$(ZWAY_INCLUDE_DIR)
LIBDIR = -L$(ZWAY_LIB_DIR)
LIBS += -lzway -lxml2 -lpthread -lcrypto
### Targets ###
all: $(TARGET)
run:
export LD_LIBRARY_PATH=$(ZWAY_LIB_DIR):$(LD_LIBRARY_PATH) && ./$(TARGET)
$(TARGET): $(OBJECTS)
$(CC) $(LIBDIR) $(TARGET_LIBDIR) $(LDFLAGS) $(TARGET_ARCH) -o $@ $< $(LIBS)
%.o: %.c $(ZWAY_LIB_DIR)/$(ZWAY_LIB).so
$(CC) $(INCLUDES) $(TARGET_INCLUDES) $(CFLAGS) $(TARGET_ARCH) -c $< -o $@
clean:
rm -f *.o $(TARGET)
.PHONY: all clean $(TARGET) run
Posted: 25 Apr 2014 13:00
by gilpel
Thank you very much for your reply.
I'm going to investigate and experiment this way. I had some favour with C API because I already have my own SMS lib written in C++). Anyway after some time spent on reading the DOC, I thinks it won't be easy without any clear samples. Start bad while automation DOC's section is refereing to a config.json tree structure which doesn't look to the one available on my PI....and I don't want to spend hours leading with retro-engineering because of a lake of documentation.
Cool ! Thanks
My last cleaned Makefile looks like yours. anyway thanks.
I eventually succeeded to compil and link, after updating LD_LIBRARY_PATH and ...it's OK
UPDATE: even if I succeeded to compile, I had to get back to v1.4.1-rc1 because with V1.5, worker thread stops after few seconds...amazing !! ...very disapointed by z-wave.me
Thanks again
Regards
Posted: 26 Apr 2014 01:24
What happens with your worker thread? Logs are apreciated.
Posted: 26 Apr 2014 13:13
by gilpel
I did new testing on a clean wheezy-raspbian version (3.10.37+ #669). Z-Way version is 1.5.0-rc1-1-ga232aeb.
It takes around 13sec to terminate itself:
pi@raspberrypi /opt/z-way-server/z-way-test $ ./z-way-test
[2014-04-26 09:43:47.358] SETDATA controller.data = Empty
[2014-04-26 09:43:47.362] SETDATA controller.data.nodeId = Empty
[2014-04-26 09:43:47.364] SETDATA controller.data.homeId = Empty
[2014-04-26 09:43:47.368] SETDATA controller.data.SUCNodeId = Empty
[2014-04-26 09:43:47.371] SETDATA controller.data.isPrimary = Empty
[2014-04-26 09:43:47.374] SETDATA controller.data.isInOthersNetwork = Empty
[2014-04-26 09:43:47.375] SETDATA controller.data.isRealPrimary = Empty
[2014-04-26 09:43:47.375] SETDATA controller.data.isSUC = Empty
[2014-04-26 09:43:47.376] SETDATA controller.data.SISPresent = Empty
[2014-04-26 09:43:47.378] SETDATA controller.data.libType = Empty
[2014-04-26 09:43:47.378] SETDATA controller.data.SDK = Empty
[2014-04-26 09:43:47.379] SETDATA controller.data.ZWlibMajor = Empty
[2014-04-26 09:43:47.380] SETDATA controller.data.ZWlibMinor = Empty
[2014-04-26 09:43:47.381] SETDATA controller.data.ZWVersion = Empty
[2014-04-26 09:43:47.382] SETDATA controller.data.ZWaveChip = Empty
[2014-04-26 09:43:47.383] SETDATA controller.data.APIVersion = Empty
[2014-04-26 09:43:47.383] SETDATA controller.data.manufacturerId = Empty
[2014-04-26 09:43:47.385] SETDATA controller.data.vendor = Empty
[2014-04-26 09:43:47.385] SETDATA controller.data.manufacturerProductType = Empty
[2014-04-26 09:43:47.386] SETDATA controller.data.manufacturerProductId = Empty
[2014-04-26 09:43:47.386] SETDATA controller.data.capabilities = Empty
[2014-04-26 09:43:47.386] SETDATA controller.data.controllerState = Empty
[2014-04-26 09:43:47.389] SETDATA controller.data.nonManagmentJobs = Empty
[2014-04-26 09:43:47.390] SETDATA controller.data.lastIncludedDevice = Empty
[2014-04-26 09:43:47.391] SETDATA controller.data.lastExcludedDevice = Empty
[2014-04-26 09:43:47.391] SETDATA controller.data.oldSerialAPIAckTimeout10ms = Empty
[2014-04-26 09:43:47.393] SETDATA controller.data.oldSerialAPIByteTimeout10ms = Empty
[2014-04-26 09:43:47.393] SETDATA controller.data.curSerialAPIAckTimeout10ms = Empty
[2014-04-26 09:43:47.394] SETDATA controller.data.curSerialAPIByteTimeout10ms = Empty
[2014-04-26 09:43:47.394] SETDATA controller.data.libVersionId = Empty
[2014-04-26 09:43:47.395] SETDATA controller.data.countJobs = Empty
[2014-04-26 09:43:47.397] SETDATA controller.data.memoryGetAddress = Empty
[2014-04-26 09:43:47.398] SETDATA controller.data.memoryGetData = Empty
[2014-04-26 09:43:47.400] SETDATA controller.data.functionClasses = Empty
[2014-04-26 09:43:47.401] SETDATA controller.data.functionClassesNames = Empty
[2014-04-26 09:43:47.401] SETDATA controller.data.softwareRevisionVersion = Empty
[2014-04-26 09:43:47.403] SETDATA controller.data.softwareRevisionId = Empty
[2014-04-26 09:43:47.404] SETDATA controller.data.softwareRevisionDate = Empty
[2014-04-26 09:43:47.404] SETDATA controller.data.nodeId = 0 (0x00000000)
[2014-04-26 09:43:47.406] SETDATA controller.data.homeId = 0 (0x00000000)
[2014-04-26 09:43:47.406] SETDATA controller.data.SUCNodeId = 0 (0x00000000)
[2014-04-26 09:43:47.407] SETDATA controller.data.isPrimary = False
[2014-04-26 09:43:47.409] SETDATA controller.data.isInOthersNetwork = False
[2014-04-26 09:43:47.410] SETDATA controller.data.isRealPrimary = False
[2014-04-26 09:43:47.411] SETDATA controller.data.isSUC = False
[2014-04-26 09:43:47.411] SETDATA controller.data.SISPresent = False
[2014-04-26 09:43:47.412] SETDATA controller.data.libType = 0 (0x00000000)
[2014-04-26 09:43:47.413] SETDATA controller.data.ZWlibMajor = 0 (0x00000000)
[2014-04-26 09:43:47.415] SETDATA controller.data.ZWlibMinor = 0 (0x00000000)
[2014-04-26 09:43:47.415] SETDATA controller.data.ZWVersion = 0 (0x00000000)
[2014-04-26 09:43:47.416] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2014-04-26 09:43:47.417] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2014-04-26 09:43:47.417] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2014-04-26 09:43:47.418] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-04-26 09:43:47.421] SETDATA controller.data.nonManagmentJobs = 0 (0x00000000)
[2014-04-26 09:43:47.421] SETDATA controller.data.oldSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-04-26 09:43:47.422] SETDATA controller.data.oldSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-04-26 09:43:47.423] SETDATA controller.data.curSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-04-26 09:43:47.424] SETDATA controller.data.curSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-04-26 09:43:47.424] SETDATA controller.data.libVersionId = 1 (0x00000001)
[2014-04-26 09:43:47.426] SETDATA controller.data.countJobs = False
[2014-04-26 09:43:47.427] SETDATA controller.data.softwareRevisionVersion = "v1.5.0-rc1-1-ga232aeb"
[2014-04-26 09:43:47.428] SETDATA controller.data.softwareRevisionId = "a232aebd0bd5f8f15345f8f1c95706a263a25f02"
[2014-04-26 09:43:47.429] SETDATA controller.data.softwareRevisionDate = "2014-02-13 03:13:44 +0400"
[2014-04-26 09:43:47.431] SETDATA controller.data.functionClasses = int[43]
[2014-04-26 09:43:47.432] [00] 2
[2014-04-26 09:43:47.434] [01] 3
[2014-04-26 09:43:47.435] [02] 4
[2014-04-26 09:43:47.435] [03] 5
[2014-04-26 09:43:47.435] [04] 6
[2014-04-26 09:43:47.436] [05] 7
[2014-04-26 09:43:47.437] [06] 8
[2014-04-26 09:43:47.437] [07] 18
[2014-04-26 09:43:47.437] [08] 19
[2014-04-26 09:43:47.438] [09] 21
[2014-04-26 09:43:47.440] [10] 22
[2014-04-26 09:43:47.441] [11] 32
[2014-04-26 09:43:47.441] [12] 33
[2014-04-26 09:43:47.442] [13] 34
[2014-04-26 09:43:47.442] [14] 35
[2014-04-26 09:43:47.444] [15] 36
[2014-04-26 09:43:47.445] [16] 65
[2014-04-26 09:43:47.445] [17] 66
[2014-04-26 09:43:47.447] [18] 70
[2014-04-26 09:43:47.447] [19] 71
[2014-04-26 09:43:47.447] [20] 72
[2014-04-26 09:43:47.448] [21] 73
[2014-04-26 09:43:47.448] [22] 74
[2014-04-26 09:43:47.449] [23] 75
[2014-04-26 09:43:47.451] [24] 76
[2014-04-26 09:43:47.451] [25] 77
[2014-04-26 09:43:47.452] [26] 80
[2014-04-26 09:43:47.454] [27] 81
[2014-04-26 09:43:47.454] [28] 82
[2014-04-26 09:43:47.454] [29] 83
[2014-04-26 09:43:47.455] [30] 84
[2014-04-26 09:43:47.455] [31] 85
[2014-04-26 09:43:47.456] [32] 86
[2014-04-26 09:43:47.457] [33] 87
[2014-04-26 09:43:47.457] [34] 96
[2014-04-26 09:43:47.458] [35] 97
[2014-04-26 09:43:47.459] [36] 98
[2014-04-26 09:43:47.461] [37] 99
[2014-04-26 09:43:47.462] [38] 128
[2014-04-26 09:43:47.462] [39] 210
[2014-04-26 09:43:47.463] [40] 211
[2014-04-26 09:43:47.463] [41] 242
[2014-04-26 09:43:47.464] [42] 243
[2014-04-26 09:43:47.465] SETDATA controller.data.functionClassesNames = string[43]
[2014-04-26 09:43:47.467] [00] "SerialAPIGetInitData"
[2014-04-26 09:43:47.467] [01] "SerialAPIApplicationNodeInformation"
[2014-04-26 09:43:47.467] [02] "ApplicationCommandHandler"
[2014-04-26 09:43:47.468] [03] "GetControllerCapabilities"
[2014-04-26 09:43:47.469] [04] "SerialAPISetTimeouts"
[2014-04-26 09:43:47.471] [05] "GetSerialAPICapabilities"
[2014-04-26 09:43:47.471] [06] "SerialAPISoftReset"
[2014-04-26 09:43:47.472] [07] "SendNodeInformation"
[2014-04-26 09:43:47.473] [08] "SendData"
[2014-04-26 09:43:47.473] [09] "GetVersion"
[2014-04-26 09:43:47.474] [10] "SendDataAbort"
[2014-04-26 09:43:47.476] [11] "GetHomeId"
[2014-04-26 09:43:47.476] [12] "MemoryGetByte"
[2014-04-26 09:43:47.476] [13] "MemoryPutByte"
[2014-04-26 09:43:47.477] [14] "MemoryGetBuffer"
[2014-04-26 09:43:47.478] [15] "MemoryPutBuffer"
[2014-04-26 09:43:47.478] [16] "GetNodeProtocolInformation"
[2014-04-26 09:43:47.478] [17] "SetDefault"
[2014-04-26 09:43:47.480] [18] "AssignReturnRoute"
[2014-04-26 09:43:47.481] [19] "DeleteReturnRoute"
[2014-04-26 09:43:47.481] [20] "RequestNodeNeighbourUpdate"
[2014-04-26 09:43:47.481] [21] "ApplicationNodeUpdate"
[2014-04-26 09:43:47.484] [22] "AddNodeToNetwork"
[2014-04-26 09:43:47.484] [23] "RemoveNodeFromNetwork"
[2014-04-26 09:43:47.484] [24] "CreateNewPrimary"
[2014-04-26 09:43:47.484] [25] "ControllerChange"
[2014-04-26 09:43:47.486] [26] "SetLearnMode"
[2014-04-26 09:43:47.486] [27] "AssignSUCReturnRoute"
[2014-04-26 09:43:47.486] [28] "EnableSUC"
[2014-04-26 09:43:47.487] [29] "RequestNetworkUpdate"
[2014-04-26 09:43:47.487] [30] "SetSUCNodeId"
[2014-04-26 09:43:47.488] [31] "DeleteSUCReturnRoute"
[2014-04-26 09:43:47.490] [32] "GetSUCNodeId"
[2014-04-26 09:43:47.490] [33] "SendSUCNodeId"
[2014-04-26 09:43:47.490] [34] "RequestNodeInformation"
[2014-04-26 09:43:47.490] [35] "RemoveFailedNode"
[2014-04-26 09:43:47.491] [36] "IsFailedNode"
[2014-04-26 09:43:47.493] [37] "ReplaceFailedNode"
[2014-04-26 09:43:47.493] [38] "GetRoutingTableLine"
[2014-04-26 09:43:47.494] [39] "WatchDogStart"
[2014-04-26 09:43:47.495] [40] "WatchDogStop"
[2014-04-26 09:43:47.496] [41] "ZMEFreqChange"
[2014-04-26 09:43:47.497] [42] "ZMERestore"
[2014-04-26 09:43:47.498] Opened device: /dev/ttyAMA0
[2014-04-26 09:43:47.500] Worker thread successfully created
[2014-04-26 09:43:47.505] Worker thread entry point
[2014-04-26 09:43:47.515] Adding job: Get controller info and supported function classes
[2014-04-26 09:43:47.520] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.535] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.535] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.544] SENT ACK
[2014-04-26 09:43:47.544] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.556] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.568] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.568] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.574] SENT ACK
[2014-04-26 09:43:47.575] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.587] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.597] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.598] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.604] SENT ACK
[2014-04-26 09:43:47.605] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.618] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.628] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.629] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.633] SENT ACK
[2014-04-26 09:43:47.635] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.646] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.657] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.658] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.663] SENT ACK
[2014-04-26 09:43:47.663] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.675] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.686] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.686] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.692] SENT ACK
[2014-04-26 09:43:47.694] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.706] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.716] Received SOF, while awaiting ACK
[2014-04-26 09:43:47.717] RECEIVED: ( 01 2B 01 07 04 02 01 47 00 02 00 03 FE 00 16 80 0C 00 00 00 E3 97 7D 80 07 00 00 80 00 00 00 00 00 00 00 00 00 00 02 00 00 80 07 00 7C )
[2014-04-26 09:43:47.724] SENT ACK
[2014-04-26 09:43:47.725] Received response, but there's no matching request (funcId = 0x07)
[2014-04-26 09:43:47.737] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-04-26 09:43:47.748] RECEIVED ACK
[2014-04-26 09:44:06.627] Job 0x07 (Get controller info and supported function classes): No RESPONSE received before timeout
[2014-04-26 09:44:06.627] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-04-26 09:44:06.627] Job 0x07 (Get controller info and supported function classes): fail
[2014-04-26 09:44:06.628] Get Serial API Capabilities returned zero.
[2014-04-26 09:44:06.628] Removing job: Get controller info and supported function classes
[2014-04-26 09:44:06.638] Worker thread exit point
[2014-04-26 09:44:06.638] Z-Way terminated
[2014-04-26 09:44:06.639] Worker thread successfully finished
[2014-04-26 09:44:06.639] Failed to negotiate with Z-Wave stick: Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
regarding the log files:
z-way-server.log
failed to execute shell script on ZDDX save notification
Z-Way.log is full of events collected during installation but nothing (according to time) during z-way-test testing.
with Z-Way version 1.4.1-rc1 it runs correctly except for a part of the code.
In the do_work(ZWay zway) in main.c, there is a piece of code which call an API function which looks like:
basic_level_holder = zway_find_device_instance_cc_data(zway, 3, 0, 0x20, "mylevel");
I just change the device ID by replacing 8 by 3. basic_level_holder always return 0. I also tested with some others funtions like zway_find_device_data(zway, 3, "devices[3].instances[0].commandClasses[0x30].data[1].level.value") which also return 0, but again I dont have any reference (Doc).
Hope it will help.
Regards
Posted: 27 Apr 2014 02:04
by pofs
Have you stopped the original z-way-server first?
Your program and the server obviously can't work together.
Posted: 27 Apr 2014 23:56
by gilpel
Thanks for your reply.
This wasn't so obvious for me as long as zway_init(&zway, ZSTR("/dev/ttyAMA0"),.... doesn't return any error (it normaly should if ttyAMA0 is already used/opened) and also because it runs with version 1.4.
Anyway I stopped the server and it runs without being terminated by itself.
Thanks a lot for your help.
Gilles
Posted: 28 Apr 2014 00:43
by pofs
Yes, this is kind of a known bug, and it is gonna be fixed in the future update.
Posted: 30 Apr 2014 15:38
by gilpel
I've performed more testing and have some questions.
While basic_level_holder = zway_find_device_instance_cc_data(zway, 7, 0, 0x30, "1.level"); succeeds to provide the callback call, it fails with basic_level_holder = zway_find_device_instance_cc_data(zway, 7, 0, 0x30, ""); as long as I'm expecting to retreive a JSON (or equivalent) array.
moreover, basic_level_holder = zway_find_device_instance_data(zway, 7, 0, "commandClasses.48.data.1.level"); returns a null holder.
I'm assuming that womething is wrong in my code, but I'm not able to figure out what exactly.
Posted: 30 Apr 2014 16:18
by pofs
moreover,
This is an expected behavior, since you cannot reference command classes as a part of data tree. That's why there are three separate functions: for device data, instance data and CC data.
Making parser understand paths like above will over-complicate it for no particular profit.
it fails with
Please provide some code. I'm not completely understanding what are you trying to do, and what exactly is not working.
