Page 3 of 6
Re: Debugger for Z-Way JavaScript
Posted: 18 Jul 2014 22:46
by dylancaponi
Thx for quick reply. Node inspector loads at that address but is not populated. It's totally empty. There's nothing under console or sources and I've clicked around the tabs at the bottom as well. Cmd + O opens a blank window with nothing to choose.
Posted: 18 Jul 2014 23:31
by kambis
Please check if your
z-way-server file in
/etc/init.d/ folder has the following entries:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/z-way-server/libs
export V8_DEBUG=yes
and don't forget to restart the z-way-server:
Posted: 19 Jul 2014 00:06
by dylancaponi
Upgraded zway to current version (woops):
Went back and changed z-way-server file again as you explained above. Restarted z-way-server and rebooted pi several times. The ssh tunnel seemed to have no effect on results.
Refreshed browser and get this in the main console:
"Page.getResourceTree failed.
ReferenceError: process is not defined"
There are now sources for all the modules, classes, etc. Does this seem right or should my resourcetree be loading?
Posted: 19 Jul 2014 00:13
by kambis
It seems you are on the road. if you see sources of all modules in your browser, then you are done.
You may find some good hints for working if you go completely through this post:
viewtopic.php?f=3422&t=20387&start=10
Good luck.
Posted: 09 Sep 2014 18:55
by klirichek
I believe port must be NOT ALWAYS 8183, but your web-port + 100.
For example, for me it is more comfortable to have z-way on the standard 80 port (since my raspberry is used just to control z-way, so no reason to don't use 80-th port).
Look here:
root@raspberrypi:/opt/home-automation# netstat -lptn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 8974/z-way-server
tcp 0 0 127.0.0.1:180 0.0.0.0:* LISTEN 8974/z-way-server
tcp 0 0 0.0.0.0:8084 0.0.0.0:* LISTEN 2012/mongoose
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2063/sshd
tcp 0 0 127.0.0.1:6010 0.0.0.0:* LISTEN 4592/0
tcp 0 0 127.0.0.1:6011 0.0.0.0:* LISTEN 5113/1
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 2012/mongoose
tcp 0 0 127.0.0.1:6012 0.0.0.0:* LISTEN 8907/4
tcp 0 0 127.0.0.1:6013 0.0.0.0:* LISTEN 8209/5
Do you see port 180? (80 + 100)?
And also, nothing about port 8183!
Posted: 12 Jan 2015 04:57
by kozlow
Hi, I can't debug...
My config:
2.0.1-rc7
export V8_DEBUG=yes
<debug-port>8183</debug-port>
From my ssh terminal:
$ node-inspector --debug-port 8183
Node Inspector v0.8.1
Visit
http://127.0.0.1:8080/debug?port=8183 to start debugging.
I soon I open my browser on
http://my-pi-ip:8080/debug?port=8183, I have:
express deprecated res.sendfile: Use res.sendFile instead ../../usr/local/lib/node_modules/node-inspector/lib/debug-server.js:17:7
undefined:1
400 Bad Request
SyntaxError: Unexpected token B
at Object.parse (native)
at Protocol.execute (_debugger.js:131:43)
at Socket.emit (events.js:95:17)
at Socket.<anonymous> (_stream_readable.js:765:14)
at Socket.emit (events.js:92:17)
at emitReadable_ (_stream_readable.js:427:10)
at emitReadable (_stream_readable.js:423:5)
at readableAddChunk (_stream_readable.js:166:9)
at Socket.Readable.push (_stream_readable.js:128:10)
at TCP.onread (net.js:529:21)
No source file in browser debug interface... Any help? Thx.
Posted: 13 Jan 2015 02:17
Node inspector should run locally or you need to make ssh tunnel like shown on first page of this topic. Please read it carefully.
Posted: 13 Jan 2015 21:35
by kozlow
OK, done, thanks, the sentence "Install Node Inspector on your PC or on Raspberry Pi" confused me.
++Mat
Posted: 15 Mar 2015 17:10
by m_pete
I could not understand, how can I debug via ssh tunnel if z-way-server listens the local connection only.
netstat -lptn
tcp 0 0 0.0.0.0:8083 0.0.0.0:* LISTEN 7077/z-way-server
tcp 0 0 0.0.0.0:8084 0.0.0.0:* LISTEN 2180/mongoose
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2252/sshd
tcp 0 0 127.0.0.1:8183 0.0.0.0:* LISTEN 7077/z-way-server
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 2180/mongoose
127.0.0.1:8183 - means - wait local connection?
Posted: 28 Jun 2015 15:01
by Isaksson
Is there a way to verify if Z-Way is listening on 8183?
I have made all steps from the first post but it does not work, i need to find out if its the server or client i need to focus on.
I am running Node Inspector on windows and i create the ssh tunnel with putty.
