Trigger example modules?
Posted: 25 Jun 2014 13:02
by dylancaponi
How are modules normally triggered? For instance, the example modules included in the zautomation folder?
I tried setting the EventLog module.json autoload value to "true" and then restarted the z-way server but wasn't sure where to look for the output / logfile. How can I trigger a sample module and check that it's running?
Re: Trigger example modules?
Posted: 29 Jun 2014 00:38
Posted: 30 Jun 2014 08:59
by dylancaponi
Thank you. I read this section again but did not find the answer to my question. Is the autoload boolean the only way to instantiate a module?
Posted: 30 Jun 2014 10:17
by kambis
Any modules located in in
automation/modules or
automation/userModules
will be started when Z-Way server starts. Have a look inside
automation/classes/AutomationController.js and search for
AutomationController.prototype.loadModules (line 111). Any subfolder containing a index.js script will be loaded. But you have to follow some rules mentioned in the doc
http://razberry.z-wave.me/docs/zwayDev.pdf, page 49
You can easily follow up which modules are running if you use debugging. Here you find instructions how to implement debugging capability to your system:
viewtopic.php?f=3422&t=20387&start=10#p51463
My understanding is that you force to start a module at startup using autoload=true. If you have created a rule in automation panel for your module, then the module will get started anyhow.
Posted: 01 Jul 2014 13:11
by dylancaponi
Thank you!
