FGD 211 did not work after hard reset
Posted: 30 Jun 2014 22:23
I make an hard reset on my razberry to reset all my configuration. I exclude and reinclude all my device but my module FGD 211 did not work now with switch if raspberry is on. If a shutdown rasberry it's ok my switch work perfectly but with raspberry on there is nothing, light did not turn on.
Nervertheless when I action the switch I can see that in log :
[2014-06-30 21:14:39.739] RECEIVED: ( 01 0D 00 04 00 0C 07 60 0D 00 01 20 01 FF 4F )
[2014-06-30 21:14:39.740] SENT ACK
[2014-06-30 21:14:39.741] SETDATA devices.12.data.lastReceived = 0 (0x00000000)
[2014-06-30 21:14:39.743] SETDATA devices.1.instances.1.commandClasses.32.data.srcNodeId = 12 (0x0000000c)
[2014-06-30 21:14:39.744] SETDATA devices.1.instances.1.commandClasses.32.data.srcInstanceId = 0 (0x00000000)
[2014-06-30 21:14:39.745] SETDATA devices.1.instances.1.commandClasses.32.data.level = 255 (0x000000ff)
So switch is correctly connect. Sometime it's work but the state is not ok on API and blue UI event if in the log it's report.
How can i solved it ? Only change it's that before device was include in 1.4.1 version and now in 1.7.1 maybe if I exlude device switch to 1.5.0 version and reinclude device it will work again. It's very anoying probleme
