Version 2
Version 2
I did notice a couple of release candidates of version 2 on the download page. Does it make sense for daring users to give that a try?
pofs
Re: Version 2
Post by pofs »
No, don't even try it yet!
They're some internal automated builds, which are not suitable for the end-user. They are hard to configure, and they have an incomplete client UI. Even if you manage to configure and run it, you'll experience a lot of issues and no support.
We'll make an announcement when it will be ready. Keep calm for a couple of weeks :)
Re: Version 2
Thanks for the status update.
Re: Version 2
Will, rc6 can work. Can ;)
Note that to make it work as usually, you will need to add in home automaton UI Z-Wave Binding module with default params. Also add Cron, Z-Wave Device Createor and Z-Wave Dead device detector. Others are up to you.
There are slight changes in API, so if you have made your modules, you might require to update them too.
Re: Version 2
I'll give the rc6 atry. Two questions first
  • I intend to run this on a separate SD card. Can I safely switch back to the card with 1.7.2? (i.e. doesn't the new version change things such that I have to reinclude/configure my devices)
  • I do not understand the part of what I have to add. If I look at the sources, modules like BindDevices, Cron, ZwaveDeadDetection are there. I don't know what more I should do.
zoic22
Re: Version 2
Post by zoic22 »
HI,
I just try this rc6 but it did not work for me :
Error handling data from server
Here, if I start manually z-way-server :
Z-Way version v2.0.0-rc6 from 2014-09-24 00:01:52 +0400 (build 4428992f61ec2a813d9d1d4962e1fa7ee12e503d)
Looking for modules in ./modules
Failed to load module mod-homekit.so: libdns_sd.so.1: cannot open shared object file: No such file or directory
Module mod-ws.so loaded
cURL 7.26.0 likely has DNS timeout bug. Please update cURL. Disabling sync DNS timeouts for now.
Module mod-http.so loaded
Module mod-zwave.so loaded
Module mod-enocean.so loaded
Module mod-dhs.so loaded
Error: 'debug-port' number is out of range. Skipping it.
Here the install (update) log :
root@jeedom /opt/z-way-server # wget -q -O - razberry.z-wave.me/install/v2.0.0-rc6  | sudo bash
Removing MathKernel
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Le paquet « wolfram-engine » n'est pas installé, et ne peut donc être supprimé
Le paquet suivant a été installé automatiquement et n'est plus nécessaire :
  libgail-3-0
Veuillez utiliser « apt-get autoremove » pour le supprimer.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Installing additional libraries
Construction de l'arbre des dépendances...
libyajl2 est déjà la plus récente version disponible.
sharutils est déjà la plus récente version disponible.
  libgail-3-0
Installing additional libraries for HomeKit
  libgail-3-0
Les paquets supplémentaires suivants seront installés :
  avahi-daemon bind9-host libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libavahi-core7 libbind9-80 libdbus-1-dev
  libdns88 libisc84 libisccc80 libisccfg82 liblwres80 libnss-mdns
Paquets suggérés :
  avahi-autoipd
Les NOUVEAUX paquets suivants seront installés :
  avahi-daemon bind9-host libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7
  libbind9-80 libdbus-1-dev libdns88 libisc84 libisccc80 libisccfg82 liblwres80 libnss-mdns
0 mis à jour, 15 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 1 342 ko/1 818 ko dans les archives.
Après cette opération, 4 558 ko d'espace disque supplémentaires seront utilisés.
Réception de : 1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libisc84 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [167 kB]
Réception de : 2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdns88 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [708 kB]
Réception de : 3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libisccc80 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [33,6 kB]
Réception de : 4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libisccfg82 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [55,0 kB]
Réception de : 5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libbind9-80 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [41,4 kB]
Réception de : 6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main liblwres80 armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [51,6 kB]
Réception de : 7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main bind9-host armhf 1:9.8.4.dfsg.P1-6+nmu2+deb7u2 [71,1 kB]
Réception de : 8 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbus-1-dev armhf 1.6.8-1+deb7u4 [214 kB]
1 342 ko réceptionnés en 1s (725 ko/s)
Sélection du paquet libavahi-compat-libdnssd1:armhf précédemment désélectionné.
(Lecture de la base de données... 73072 fichiers et répertoires déjà installés.)
Dépaquetage de libavahi-compat-libdnssd1:armhf (à partir de .../libavahi-compat-libdnssd1_0.6.31-2_armhf.deb) ...
Sélection du paquet libavahi-core7:armhf précédemment désélectionné.
Dépaquetage de libavahi-core7:armhf (à partir de .../libavahi-core7_0.6.31-2_armhf.deb) ...
Sélection du paquet libisc84 précédemment désélectionné.
Dépaquetage de libisc84 (à partir de .../libisc84_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet libdns88 précédemment désélectionné.
Dépaquetage de libdns88 (à partir de .../libdns88_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet libisccc80 précédemment désélectionné.
Dépaquetage de libisccc80 (à partir de .../libisccc80_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet libisccfg82 précédemment désélectionné.
Dépaquetage de libisccfg82 (à partir de .../libisccfg82_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet libbind9-80 précédemment désélectionné.
Dépaquetage de libbind9-80 (à partir de .../libbind9-80_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet liblwres80 précédemment désélectionné.
Dépaquetage de liblwres80 (à partir de .../liblwres80_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet bind9-host précédemment désélectionné.
Dépaquetage de bind9-host (à partir de .../bind9-host_1%3a9.8.4.dfsg.P1-6+nmu2+deb7u2_armhf.deb) ...
Sélection du paquet avahi-daemon précédemment désélectionné.
Dépaquetage de avahi-daemon (à partir de .../avahi-daemon_0.6.31-2_armhf.deb) ...
Sélection du paquet libavahi-common-dev précédemment désélectionné.
Dépaquetage de libavahi-common-dev (à partir de .../libavahi-common-dev_0.6.31-2_armhf.deb) ...
Sélection du paquet libdbus-1-dev précédemment désélectionné.
Dépaquetage de libdbus-1-dev (à partir de .../libdbus-1-dev_1.6.8-1+deb7u4_armhf.deb) ...
Sélection du paquet libavahi-client-dev précédemment désélectionné.
Dépaquetage de libavahi-client-dev (à partir de .../libavahi-client-dev_0.6.31-2_armhf.deb) ...
Sélection du paquet libavahi-compat-libdnssd-dev précédemment désélectionné.
Dépaquetage de libavahi-compat-libdnssd-dev (à partir de .../libavahi-compat-libdnssd-dev_0.6.31-2_armhf.deb) ...
Sélection du paquet libnss-mdns précédemment désélectionné.
Dépaquetage de libnss-mdns (à partir de .../libnss-mdns_0.10-3.2_armhf.deb) ...
Traitement des actions différées (« triggers ») pour « man-db »...
Paramétrage de libavahi-compat-libdnssd1:armhf (0.6.31-2) ...
Paramétrage de libavahi-core7:armhf (0.6.31-2) ...
Paramétrage de libisc84 (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de libdns88 (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de libisccc80 (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de libisccfg82 (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de libbind9-80 (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de liblwres80 (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de bind9-host (1:9.8.4.dfsg.P1-6+nmu2+deb7u2) ...
Paramétrage de avahi-daemon (0.6.31-2) ...
[ ok ] Reloading system message bus config...done.
[ ok ] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Paramétrage de libavahi-common-dev (0.6.31-2) ...
Paramétrage de libdbus-1-dev (1.6.8-1+deb7u4) ...
Paramétrage de libavahi-client-dev (0.6.31-2) ...
Paramétrage de libavahi-compat-libdnssd-dev (0.6.31-2) ...
Paramétrage de libnss-mdns (0.10-3.2) ...
First installation detected...
Checking NSS setup...
Getting Z-Way for Raspberry Pi
--2014-09-24 21:48:06--  http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.0.0-rc6.tgz
Résolution de razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connexion vers razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80...connecté.
requête HTTP transmise, en attente de la réponse...200 OK
Longueur: 18370163 (18M) [application/x-gzip]
Sauvegarde en : «STDOUT»
100%[===================================================================================================================================================================================================>] 18 370 163  1,05M/s   ds 14s
2014-09-24 21:48:20 (1,27 MB/s) - envoi vers sortie standard [18370163/18370163]
Previous z-way-server installation found
Stopping z-way-server: rm: impossible de supprimer « /var/run/z-way-server.pid »: Aucun fichier ou dossier de ce type
done.
Stopping mongoose http server
Making backup of previous version of Z-Way in /opt/z-way-server_2014-09-24-21-48-30
Copying settings
!!! Defaults.xml and config.xml updated with new versions !!!
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
--2014-09-24 21:48:32--  http://razberry.z-wave.me/webif_raspberry.tar.gz
Longueur: 408241 (399K) [application/x-gzip]
100%[===================================================================================================================================================================================================>] 408 241     1,05M/s   ds 0,4s
2014-09-24 21:48:32 (1,05 MB/s) - envoi vers sortie standard [408241/408241]
[....] Stoping zbw_connect:[info] ok.
zbw_connect patched
[....] Starting zbw_connect:[info] ok.
--2014-09-24 21:48:33--  http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Longueur: 44749 (44K) [application/x-gzip]
100%[===================================================================================================================================================================================================>] 44 749      --.-K/s   ds 0,07s
2014-09-24 21:48:33 (637 KB/s) - envoi vers sortie standard [44749/44749]
Adding mongoose to autostart
Start mongoose http server
./z-cfg-update: /usr/lib/arm-linux-gnueabihf/libxml2.so.2: version `LIBXML2_2.9.1' not found (required by ./z-cfg-update)
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
How can I help you to solved this ? Maybe 2.0.0 work only on fresh install ?
Thank in adavnce
pofs
Re: Version 2
Post by pofs »
Install script currently doesn't know about some new dependencies, so might fail.
As I said earlier, you'll experience issues :)
You better install on a new storage card to not ruin the existing installation.
As of libxml
it looks really strange. Probably it linked a different version of libxml because of migration to a new build server. Try updating libxml on your box.
zoic22
Re: Version 2
Post by zoic22 »
It's test box so I can have issue (before pass to production environnement).
I check libxml I have 2.8.0 version :
root@jeedom ~ # ll /usr/lib/arm-linux-gnueabihf/libxml2*
lrwxrwxrwx 1 root root      16 juil. 11 17:58 /usr/lib/arm-linux-gnueabihf/libxml2.so.2 -> libxml2.so.2.8.0
-rw-r--r-- 1 root root 1196108 juil. 11 17:58 /usr/lib/arm-linux-gnueabihf/libxml2.so.2.8.0
So I make apt-get update et apt-get install libxml2 but no new version. I check repository :
root@jeedom /opt/z-way-server # apt-cache policy libxml2
libxml2:
  Installé : 2.8.0+dfsg1-7+wheezy1
  Candidat : 2.8.0+dfsg1-7+wheezy1
 Table de version :
 *** 2.8.0+dfsg1-7+wheezy1 0
        500 http://mirrordirector.raspbian.org/raspbian/ wheezy/main armhf Packages
        100 /var/lib/dpkg/status
No 2.9.1 version. I can install it manually or maybe you have a repository I can add to do that ?
pofs
Re: Version 2
Post by pofs »
zoic22 wrote:No 2.9.1 version. I can install it manually or maybe you have a repository I can add to do that ?
No idea where to get it except for building from source.
You'd better wait for the next build, it might be solved there.
Re: Version 2
We apologize, we forgot to include libxml.so.2.9.1 in the build. Please run update script again (to the same version rc6) and you will get it.
