Virgin installation not working
Posted: 18 Nov 2014 10:10
service doesn't seem to start
running LD_LIBRARY_PATH=libs ./z-way-server gives the following:
Starting Z-Way for device /dev/ttyAMA0...
failed to discover ZWay: Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
Is the hardware defective?
