z-way-server won't start, failed to discover...
Posted: 23 Nov 2014 03:29
by epatdwelo
Bad configuration or bad RaZberry? Here's the data...
after running wget -q -O - http://razberry.z-wave.me/install | sudo bash
and doing my best (new here) to make sure I have the latest lubuntu updates.
>/etc/init.d/z-way-server start
Starting z-way-server: done.
root@lemaker:/opt/z-way-server# Z-Way version v1.7.2 from 2014-07-26 15:20:00 +0400 (build 428d48e765a32b39615c073af93e8666497724c9)
Starting Z-Way for device /dev/ttyS0...
failed to discover ZWay: Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
cat config.xml
<config>
<device>/dev/ttyS0</device>
<config-dir></config-dir>
<translations-dir></translations-dir>
<zddx-dir></zddx-dir>
<port>8083</port>
<http-root-dir>./htdocs</http-root-dir>
<automation-dir>automation</automation-dir>
<shell-script-on-save-xml>sync</shell-script-on-save-xml>
<shell-script-on-save-http>sync</shell-script-on-save-http>
<log-file>/var/log/z-way-server.log</log-file>
<log-level>0</log-level>
<http-log-file>/var/log/z-way-server.log</http-log-file>
<http-log-level>0</http-log-level>
</config>
>cat z-way-server.log
[2014-11-23 08:18:25.823] SETDATA controller.data = Empty
[2014-11-23 08:18:25.824] SETDATA controller.data.nodeId = Empty
[2014-11-23 08:18:25.824] SETDATA controller.data.homeId = Empty
[2014-11-23 08:18:25.824] SETDATA controller.data.SUCNodeId = Empty
[2014-11-23 08:18:25.824] SETDATA controller.data.isPrimary = Empty
[2014-11-23 08:18:25.824] SETDATA controller.data.isInOthersNetwork = Empty
[2014-11-23 08:18:25.824] SETDATA controller.data.isRealPrimary = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.isSUC = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.SISPresent = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.libType = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.SDK = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.ZWlibMajor = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.ZWlibMinor = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.ZWVersion = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.ZWaveChip = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.APIVersion = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.manufacturerId = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.vendor = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.manufacturerProductType = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.manufacturerProductId = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.capabilities = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.controllerState = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.nonManagmentJobs = Empty
[2014-11-23 08:18:25.825] SETDATA controller.data.lastIncludedDevice = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.lastExcludedDevice = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.secureInclusion = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.oldSerialAPIAckTimeout10ms = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.oldSerialAPIByteTimeout10ms = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.curSerialAPIAckTimeout10ms = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.curSerialAPIByteTimeout10ms = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.libVersionId = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.countJobs = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.memoryGetAddress = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.memoryGetData = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.memoryManufacturerId = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.memoryType = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.memoryCapacity = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.functionClasses = Empty
[2014-11-23 08:18:25.826] SETDATA controller.data.functionClassesNames = Empty
[2014-11-23 08:18:25.827] SETDATA controller.data.softwareRevisionVersion = Empty
[2014-11-23 08:18:25.827] SETDATA controller.data.softwareRevisionId = Empty
[2014-11-23 08:18:25.827] SETDATA controller.data.softwareRevisionDate = Empty
[2014-11-23 08:18:25.827] SETDATA controller.data.nodeId = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.homeId = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.SUCNodeId = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.isPrimary = False
[2014-11-23 08:18:25.827] SETDATA controller.data.isInOthersNetwork = False
[2014-11-23 08:18:25.827] SETDATA controller.data.isRealPrimary = False
[2014-11-23 08:18:25.827] SETDATA controller.data.isSUC = False
[2014-11-23 08:18:25.827] SETDATA controller.data.SISPresent = False
[2014-11-23 08:18:25.827] SETDATA controller.data.libType = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.ZWlibMajor = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.ZWlibMinor = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.ZWVersion = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.manufacturerId = 0 (0x00000000)
[2014-11-23 08:18:25.827] SETDATA controller.data.manufacturerProductType = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.manufacturerProductId = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.nonManagmentJobs = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.secureInclusion = True
[2014-11-23 08:18:25.828] SETDATA controller.data.oldSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.oldSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.curSerialAPIAckTimeout10ms = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.curSerialAPIByteTimeout10ms = 0 (0x00000000)
[2014-11-23 08:18:25.828] SETDATA controller.data.libVersionId = 1 (0x00000001)
[2014-11-23 08:18:25.828] SETDATA controller.data.countJobs = False
[2014-11-23 08:18:25.828] SETDATA controller.data.softwareRevisionVersion = "v1.7.2"
[2014-11-23 08:18:25.828] SETDATA controller.data.softwareRevisionId = "428d48e765a32b39615c073af93e8666497724c9"
[2014-11-23 08:18:25.828] SETDATA controller.data.softwareRevisionDate = "2014-07-26 15:20:00 +0400"
[2014-11-23 08:18:25.829] SETDATA controller.data.functionClasses = int[48]
[2014-11-23 08:18:25.829]   [00] 2
[2014-11-23 08:18:25.829]   [01] 3
[2014-11-23 08:18:25.829]   [02] 4
[2014-11-23 08:18:25.829]   [03] 5
[2014-11-23 08:18:25.829]   [04] 6
[2014-11-23 08:18:25.829]   [05] 7
[2014-11-23 08:18:25.829]   [06] 8
[2014-11-23 08:18:25.829]   [07] 18
[2014-11-23 08:18:25.829]   [08] 19
[2014-11-23 08:18:25.829]   [09] 21
[2014-11-23 08:18:25.829]   [10] 22
[2014-11-23 08:18:25.829]   [11] 32
[2014-11-23 08:18:25.829]   [12] 33
[2014-11-23 08:18:25.829]   [13] 34
[2014-11-23 08:18:25.829]   [14] 35
[2014-11-23 08:18:25.830]   [15] 36
[2014-11-23 08:18:25.830]   [16] 41
[2014-11-23 08:18:25.830]   [17] 42
[2014-11-23 08:18:25.830]   [18] 43
[2014-11-23 08:18:25.830]   [19] 44
[2014-11-23 08:18:25.830]   [20] 45
[2014-11-23 08:18:25.830]   [21] 65
[2014-11-23 08:18:25.830]   [22] 66
[2014-11-23 08:18:25.830]   [23] 70
[2014-11-23 08:18:25.830]   [24] 71
[2014-11-23 08:18:25.830]   [25] 72
[2014-11-23 08:18:25.830]   [26] 73
[2014-11-23 08:18:25.830]   [27] 74
[2014-11-23 08:18:25.830]   [28] 75
[2014-11-23 08:18:25.830]   [29] 76
[2014-11-23 08:18:25.830]   [30] 77
[2014-11-23 08:18:25.830]   [31] 80
[2014-11-23 08:18:25.830]   [32] 81
[2014-11-23 08:18:25.830]   [33] 82
[2014-11-23 08:18:25.830]   [34] 83
[2014-11-23 08:18:25.831]   [35] 84
[2014-11-23 08:18:25.831]   [36] 85
[2014-11-23 08:18:25.831]   [37] 86
[2014-11-23 08:18:25.831]   [38] 87
[2014-11-23 08:18:25.831]   [39] 96
[2014-11-23 08:18:25.831]   [40] 97
[2014-11-23 08:18:25.831]   [41] 98
[2014-11-23 08:18:25.831]   [42] 99
[2014-11-23 08:18:25.831]   [43] 128
[2014-11-23 08:18:25.831]   [44] 210
[2014-11-23 08:18:25.831]   [45] 211
[2014-11-23 08:18:25.831]   [46] 242
[2014-11-23 08:18:25.831]   [47] 243
[2014-11-23 08:18:25.831] SETDATA controller.data.functionClassesNames = string[48]
[2014-11-23 08:18:25.831]   [00] "SerialAPIGetInitData"
[2014-11-23 08:18:25.831]   [01] "SerialAPIApplicationNodeInformation"
[2014-11-23 08:18:25.831]   [02] "ApplicationCommandHandler"
[2014-11-23 08:18:25.832]   [03] "GetControllerCapabilities"
[2014-11-23 08:18:25.832]   [04] "SerialAPISetTimeouts"
[2014-11-23 08:18:25.832]   [05] "GetSerialAPICapabilities"
[2014-11-23 08:18:25.832]   [06] "SerialAPISoftReset"
[2014-11-23 08:18:25.832]   [07] "SendNodeInformation"
[2014-11-23 08:18:25.832]   [08] "SendData"
[2014-11-23 08:18:25.832]   [09] "GetVersion"
[2014-11-23 08:18:25.832]   [10] "SendDataAbort"
[2014-11-23 08:18:25.832]   [11] "GetHomeId"
[2014-11-23 08:18:25.832]   [12] "MemoryGetByte"
[2014-11-23 08:18:25.832]   [13] "MemoryPutByte"
[2014-11-23 08:18:25.832]   [14] "MemoryGetBuffer"
[2014-11-23 08:18:25.832]   [15] "MemoryPutBuffer"
[2014-11-23 08:18:25.832]   [16] "NVMGetId"
[2014-11-23 08:18:25.832]   [17] "NVMExtReadLongBuffer"
[2014-11-23 08:18:25.832]   [18] "NVMExtWriteLongBuffer"
[2014-11-23 08:18:25.832]   [19] "NVMExtReadLongByte"
[2014-11-23 08:18:25.832]   [20] "NVMExtWriteLongByte"
[2014-11-23 08:18:25.833]   [21] "GetNodeProtocolInformation"
[2014-11-23 08:18:25.833]   [22] "SetDefault"
[2014-11-23 08:18:25.833]   [23] "AssignReturnRoute"
[2014-11-23 08:18:25.833]   [24] "DeleteReturnRoute"
[2014-11-23 08:18:25.833]   [25] "RequestNodeNeighbourUpdate"
[2014-11-23 08:18:25.833]   [26] "ApplicationNodeUpdate"
[2014-11-23 08:18:25.833]   [27] "AddNodeToNetwork"
[2014-11-23 08:18:25.833]   [28] "RemoveNodeFromNetwork"
[2014-11-23 08:18:25.833]   [29] "CreateNewPrimary"
[2014-11-23 08:18:25.833]   [30] "ControllerChange"
[2014-11-23 08:18:25.833]   [31] "SetLearnMode"
[2014-11-23 08:18:25.833]   [32] "AssignSUCReturnRoute"
[2014-11-23 08:18:25.833]   [33] "EnableSUC"
[2014-11-23 08:18:25.833]   [34] "RequestNetworkUpdate"
[2014-11-23 08:18:25.833]   [35] "SetSUCNodeId"
[2014-11-23 08:18:25.833]   [36] "DeleteSUCReturnRoute"
[2014-11-23 08:18:25.833]   [37] "GetSUCNodeId"
[2014-11-23 08:18:25.833]   [38] "SendSUCNodeId"
[2014-11-23 08:18:25.833]   [39] "RequestNodeInformation"
[2014-11-23 08:18:25.833]   [40] "RemoveFailedNode"
[2014-11-23 08:18:25.834]   [41] "IsFailedNode"
[2014-11-23 08:18:25.834]   [42] "ReplaceFailedNode"
[2014-11-23 08:18:25.834]   [43] "GetRoutingTableLine"
[2014-11-23 08:18:25.834]   [44] "WatchDogStart"
[2014-11-23 08:18:25.834]   [45] "WatchDogStop"
[2014-11-23 08:18:25.834]   [46] "ZMEFreqChange"
[2014-11-23 08:18:25.834]   [47] "ZMERestore"
[2014-11-23 08:18:25.834] Opened device: /dev/ttyS0
[2014-11-23 08:18:25.835] Worker thread successfully created
[2014-11-23 08:18:25.835] Worker thread entry point
[2014-11-23 08:18:25.845] Adding job: Get controller info and supported function classes
[2014-11-23 08:18:25.848] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-11-23 08:18:26.027] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-11-23 08:18:26.038] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-11-23 08:18:26.217] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-11-23 08:18:26.229] SENDING (cb 0x07): ( 01 03 00 07 FB )
[2014-11-23 08:18:26.408] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-11-23 08:18:26.408] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-11-23 08:18:26.408] Job 0x07 (Get controller info and supported function classes): fail
[2014-11-23 08:18:26.409] Get Serial API Capabilities returned zero.
[2014-11-23 08:18:26.409] Removing job: Get controller info and supported function classes
[2014-11-23 08:18:26.419] Worker thread exit point
[2014-11-23 08:18:26.419] Worker thread successfully finished
[moderator edit] log placed in code block
Re: z-way-server won't start, failed to discover...
Posted: 23 Nov 2014 16:24
by pofs
I assume you're not on Raspbian, so your port is /dev/ttyS0 instead of /dev/ttyAMA0 ?
Installer script is built for Raspberry Pi and Raspbian OS, so it cannot reconfigure the port it knows nothing about. You should manually remove console from that port (look into your OS manual to know how to do that).
