V2.0.0. Editing Switch All on/off mode fails
hpd
Post by hpd »
Switch all on/off mode Settings for Fibaro FGS-211 Swithes and FGS-221 Switches are ignored by expert ui. I can Change the Settings to whatever I want. Expert UI does not show the little green Icon for this feature.
I am as well wondering why we have for instance Parameter 1 in FGS-221 which appears to be the same as the Parameter block with similar namings at the end of configuration.
Trying to compare the behaviour with blue ui I noticed following error message if I try to change configuration:
>> Command execution failed due to some error on the Server. Internal Server Error <<
I could not see anything Special in the z-way-Server log
Z-Way 2.0.0-final on Raspberry Pi
hpd
Re: V2.0.0. Editing Switch All on/off mode fails
Post by hpd »
nobody of zway team interested in this misbehaviour?
If my explanation is unclear, let me know.I am happy to provide more and better explanations.
pofs
Post by pofs »
Please capture network request details (in your browser developer tools) when you get "Command execution failed" message.
Also try to send on/off from url and see if it works: http://ip:8083/ZWaveAPI/Run/devices[x].SwitchAll.SetOn()
It is a bit unclear about parameter 1, so provide some details/screenshots please.
hpd
Post by hpd »
Unfortunately I do not know how to upload screen shots into this forum . I will send you a better explanation via Email.
