Hi all,
need your help for a couple of issues related to version 2.0.0
1)
I used the following command to turn off a device.
http://192.168.1.22:8083/ZAutomation/Op ... aryOff/5/0
Now I see the following error: Invalid ZAutomation request
2) In Z-Way Home Automation UI how we can hide Warning message? the Hide button doesn't exist any more
EDIT: forget question 2. I have seen PoltoS reply in another post
2.0.0 - a couple of issues
Re: 2.0.0 - a couple of issues
You must leave the ZAutomation part out of your path. See recipes section for OpenRemoteHelpers
http://192.168.1.22:8083/OpenRemote/SwitchBinaryOff/5/0
The calling url is changed in v2.0.0
for me:
was: http://127.0.0.1:8083/ZAutomation/api/v ... Dev_3:1:37
now: http://127.0.0.1:8083/ZAutomation/api/v ... way_3-1-37
Hope this helps you.
for me:
There are several API's to RaZberry. Afaik the thing you are talking about is the vitual devices Apiary APIbillyboy wrote:The calling url is changed in v2.0.0
for me:
Solorflor is using the OpenRemote API, which uses the old zwave api inside. My answer was adressing that interface.
Many Thanks. It workspz1 wrote:You must leave the ZAutomation part out of your path. See recipes section for OpenRemoteHelpers
Many thanks billiboy.billyboy wrote:The calling url is changed in v2.0.0
for me:
I'm using OpenRemote API and I have fixed the issues thanks to pz1
To be more specific, not API changed, but IDs changed. We replaced special character : by - in devices ID for extensions like iRidium mobile and added zway object name as you can have many dongles together.
